Reply 540 of 575, by myne
Which version of the installer are you using?
Dxwnd was fixed a few months ago, and a new pack compiled into the installer.
There aren't any reports of it failing, and I finished mercs Titanium with minimal issues.
I built:
Reply 541 of 575, by Deffnator
myne wrote on 2025-07-30, 16:04:
i am using the newest version that was posted here recently
Reply 542 of 575, by old school gamer man
is there a way to play the hardware 3d versions on xp? the powervr one more than anything. the matrox one too?
Reply 543 of 575, by Deffnator
old school gamer man wrote on 2025-07-30, 16:38:
those runs naturally using the mech2.org instructions, but depends if there are drivers for it, 3dfx runs fine thanks to nglide and MW2hook or the xp patch.
Reply 544 of 575, by old school gamer man
Deffnator wrote on 2025-07-31, 14:25:
even if you don't have a power vr or matrox card?
Reply 545 of 575, by Deffnator
old school gamer man wrote on 2025-07-31, 16:40:
Unfortunately there is no Matrox or PowerVR wrappers
Reply 546 of 575, by old school gamer man
Deffnator wrote on 2025-07-31, 19:19:
that sucks.
Reply 547 of 575, by Deffnator
So i decided to put my dxwnd configuration as dgvoodoo config for Been_nath and myne to investigate as others here who may know better.
I gave a better feedback at the dgvoodoo's thread, under this config not only titanium is running great though it has some issues related to memory during a mission once in a while, this may also be a problem under direct3d, but for some reason dxwnd and mercs menu aren't agreeing with each other and the menu is always stuck on top left of the screen and cant be scaled at all without issues, ot kept in windowed mode as it should be.
The attachment dxwnd.ini is no longer available
The attachment dgVoodoo.conf is no longer available
my only wish is for a WASD config based on Mech5+MWO's default settings, but i finished these games before on the og scheme years ago.
Reply 548 of 575, by myne
Need more details.
What versions? Preferably with the string copied from the installer. Eg
Ie, cdlabel, productid, productname from the product.Ini
What's the problem?
What are you trying to do that makes the defaults in the installer unsuitable?
How will others benefit?
I built:
Reply 549 of 575, by Deffnator
myne wrote on 2025-08-02, 00:08:
Need more details. What versions? Preferably with the string copied from the installer. Eg Ie, cdlabel, productid, productname […]
Need more details.
What's the problem?
this is from the last mw2installer+latest dgvoodoo2 build for mercs titanium, i also gave the entire feedback at the dgvoodoo subforum thread.
here in this case is to solve out the erratic behavior of the main menu window+direct3d resolution, on which i gave up after tweaking video and main for hours on dxwnd.
Reply 550 of 575, by myne
4 questions. 2 answered.
I'm not a dentist. I don't have the patience to pull teeth.
I built:
Reply 551 of 575, by GryBsh
I am in no way suggesting there is anything wrong with the installer script included with the patch files. It certainly works.
I wanted it to work in new PowerShell and I wanted uninstall entries.
I'm not a person who comes to a forum to complain about anyone's hard effort freely given, SO, attached is an updated script that does both.
I also cleaned it up a bit, added parameters, swapped out some aliases for cmdlet names, fixed some casing, and function-afied it, so it a bit easier for the next person to tinker on.
It takes 2 parameters:
InstallPath: where to install the game, it will prompt for it if omitted.
And a switch NoConfirm: removes any and all confirmation prompts.
It will also add 2 scripts to the install folder, 1 to launch it the same way as the shortcut and one that removes all the files and the shortcut that will get launched from Settings.
The launch script is for any launcher apps (ESDE, LaunchBox, etc) so I don't have to go get the args from the shortcut myself, because I'm lazy. 🤣
And because it adds the uninstall entries in the registry you will need to run it as an administrator.
It has a #requires -RunAsAdmin on it, so it should just fail if you have not elevated.
Reply 552 of 575, by GryBsh
A quick fix for the shortcut target coming out wrong under some cases.
Reply 553 of 575, by myne
Haven't tested it, but I did actually start on a more function based version, that read inis for config, and had a gui.
Maybe you want to finish it?
I built:
Reply 554 of 575, by GryBsh
I can certainly take a look and see what I can do with it.
Reply 555 of 575, by myne
This looks like it
I built:
Reply 556 of 575, by GryBsh
It took me a bit to get back to this. I took a look at your script.
Windows forms is kind of a pain to write in PowerShell. I propose this (attached).
This is all XAML, easier to tinker on and customize than straight code. Still works in Windows PowerShell and new PowerShell.
I had to get a little hacky getting the font to load, you'll know it when you see it.
Someone at MS decided that the XAML parser doesn't need to load loose files from loose XAML because WinUI doesn't ever load loose files.
According to their Github issues, they have no plans to fix it. So I need to place the font into the users font folder, if it's not already there.
Reply 557 of 575, by myne
Looks great!
You got rid of all the ini stuff though?
The goal was to make it more easy to test and add editions/configurations
I built:
Reply 558 of 575, by GryBsh
I was mostly focused on not breaking the installer, and I think I did anyway, I'm still tinkering on it. Definitely still a WIP. This is still based on my tinkered version of the script, not your most recent posting. The edition settings are all in a psd1 file in the installer folder because that was easy enough to do quickly, so I could show what I was thinking. I'm johnny come lately here, so if it wasn't well received, I wasn't going to push it.
I am working on merging this UI and the code you posted last now as I have time, I image I'll have something solid by weeks end.
I also had to take some time and remember how to WPF too. Its been a minute. 😁
Reply 559 of 575, by GryBsh
I couldn't get that code to do anything for me, so I went back to the script I already had that worked. But I get the gist of what you were going for.
The attached is working at least with the Titanium trilogy, can select between multiple mounted/inserted editions, is driven by an INI file, and provides visual feedback of progress.
It also switches colors based on which game you install.
The INI structure isn't as dense, but its easier to read and parse.
[Editions]
"MECH2-MW2W-MechWarrior 2"=MW2W
"MECH2-MW2A-MechWarrior 2"=MW2A
"MECH2-MW2W95-MechWarrior 2"=MW2W
"TIT-MW2W95-MW2 Titanium Edition"=TITMW2W95
"TITAN_MW2-TITMW2W95-Titanium Trilogy"=TITMW2W95
"GBLWIN95-GBW-Ghost Bear's Legacy"=GBW
"GBL-GBLW95DOS-Ghost Bear's Legacy"=GBLW95DOS
"TITAN_GBL-TITW95-Titanium Trilogy"=TITGBLW95
"MERCS3DFX-MERCS3DFX-Mercenaries 3DFX"=mercs3dfx
"MERCENARIES-MercsW95-Mercenaries"=MercsW95
"Mercenaries-Mercs3DSW95-Mercenaries D3D"=Mercs3DSW95
"TITAN_MERCS-TITMERW95-Mercenaries Titanium Edition"=TITMERW95
"TITAN_MERCS-TITMERW95-Mercenaries"=TITMERW95
"TITAN_MERCS-TITW95-Titanium Trilogy"=TITW95
"BATL_GBL-BtpkW95-BattlePack"=BPGBL
"BATL_MW2-BtpkW95-BattlePack"=BP31CC
"TITAN_MW2-TITMW2W95-MW2 Titanium Edition"=TITMW2W95
"TITAN_MW2-TITW95-Titanium Trilogy"=TITMW2W95
; MechWarrior 2 - 31st Century Combat 3Dfx Edition
[MW2A]
cdexe=mech2.ex_
origexe=mech2.exe
renameexename=mech2.exe
dxwicon=dxwmw2icon
compatpatch=mech2startupfix.sdb
shortcuticon=mech2.exe
movehelp=false
copycommonfiles=true
copydirectplay=true
copytitfixes=true
copyfolders=Keating|smk|mek|giddi
copyotherfolders=mech2
copyfiles=skygnd.par|mw2shell.dll|*.txt|*.bwd|*w*32.dll|*w.dll|*.hlp|*.cfg|*.mw2|*.map|*.fts|*.gid|*.out|*.bak|mw2.*
copy11mw2patch=false
copy11gblpatch=false
copy11merpatch=false
copy3dfxpatch=true
install=true
delfiles=
title=MechWarrior 2 - 31st Century Combat 3Dfx Edition
id="{edb77b07-a4f5-44b1-95e3-dcfabeaf7ba5}" ; for the uninstaller
