Reply 55460 of 57981, by Shadzilla
The attachment 2024-12-12 10.44.33 Large.jpeg is no longer available
I picked this up on Wednesday because it's the same case as the PC my family bought in 1997 from Tiny here in the UK. They seem to be quite hard to find now? It doesn't help that searching for 'tiny pc' gets you completely useless results! Ours was AT and S7 P200, this one is ATX and contains MSI MS-6119 board, PIII 450, 384MB ram, 6GB and 12GB HDDs, Geforce 4 MX 420, a Yamaha sound card, a modem, and a wifi card. The optical drive doesn't read discs. I'm assuming the ram has been upgraded from a 128MB base, the 12GB HDD added (the one floating around...), graphics card changed, and wifi card added. The chassis and 6GB drive are dated March 1999.
Amazingly though I just cleaned it out and it fired right up and booted into a WinXP install.
I'll retrobrite the front panel in the spring when the sun reappears and then set about building a replica of our old Socket 7 PC in it 😀
Reply 55462 of 57981, by G-X
Xicor wrote on 2024-12-10, 14:41:
Finally, a gorgeous SunFire V250 rescued from the jaws of the recycler:
That's a beautiful case! I know nothing about the internals of SUN systems but that case is awesome.
Reply 55463 of 57981, by keropi
got some uninteresting cards today and these floppies were included in the lot:
inside the win3.1 floppy the readme states:
I find it interesting that Trio32/64 are considered "minimal specs" ... I wonder if this XING MPEG player version is something of a S3 special or not... anyone knows ?
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 55464 of 57981, by Kahenraz
Can you upload these floppies somewhere? I'm fairly certain that I have a laptop with one of those Vision controllers. I didn't know that they supported mpeg decoding.
Reply 55465 of 57981, by Bruno128
Shadzilla wrote on 2024-12-13, 15:30:
Nice case. I’m pretty sure it has AT mobo screw positions (but you’ll want AT to ATX i/o shield with DIN KB cutout) as well as latching AT PSU switch mount holes (since you are removing front panel for retrobrighting anyway worth taking a look, switches are sold new)
SBEMU compatibility reports list | Navigation thread
Reply 55466 of 57981, by PcBytes
A bit of chat with the seller I will be getting the 5EMA and Commate S7AX from, and he added a Matrox Parhaelia to the pack too 😀
Reply 55467 of 57981, by Shadzilla
Bruno128 wrote on 2024-12-13, 20:07:
This is pretty much exactly my plan, they're nice and easy to convert between the two form factors 😀
Reply 55468 of 57981, by MMaximus
Xicor wrote on 2024-12-12, 15:43:
Finlay found a Roland SCC1 at a "reasonable" price, and it just arrived: […]
The attachment SCC1_01.jpg is no longer available
The attachment SCC1_02.jpg is no longer available
Complete in box. It wasn't crazy expensive, but not trivial either. The tipping factor was all the paperwork and box. Cursed luck I guess.....
Nice purchase. What's this 4-pin speaker cable doing there? Definitely not part of the original package AFAIK
Hard Disk Sounds
Reply 55469 of 57981, by Jccwu
unfrequent daughter board Aztech Sound Galaxy Wave Power
Sound card's music
Reply 55470 of 57981, by PcBytes
Another FIC PA-2013 😀
So to recap, I'm going to receive these somewhere before Christmas:
-Soyo 5EMA+ v1.1
-Commate S7AX
-FIC PA-2013
-Matrox Parhaelia 128M
Anything to look out for with each of them, besides recapping? I'm aware of FIC's tendency to burn the AGP regulator up, despite being a rev2 board. (not sure if 2.1 tho, but it looks to be the 2MB version for all I can tell)
Reply 55471 of 57981, by BitWrangler
keropi wrote on 2024-12-13, 17:53:
got some uninteresting cards today and these floppies were included in the lot: […]
There are Xing players for other cards, I think it's a Trident TGUI 9680 my disk is for. There was some detection going on because usually you couldn't get one version to work with another card, even if that chipset line had same basic support and Xing was offered with their cards.... sometimes you didn't get the whole package with "white box" OEM cards.
Reply 55472 of 57981, by keropi
BitWrangler wrote on 2024-12-14, 17:57:
interesting, I did not knew such versions existed...back then even if I had a card that came with these floppies I would probably ditch them or forget about it tbh 🤣
Reply 55473 of 57981, by BitWrangler
Back in the day, 95-97ish, it seemed like the S3 cards always came with it, whereas other chipsets it seemed more like "manufacturers whim".
Reply 55474 of 57981, by Ozzuneoj
Jccwu wrote on 2024-12-14, 16:28:
Wow, that is super cool!
It's basically an original Ensoniq SoundscapeDB with 2MB ROM (containing 4MB of compressed samples), but with a different layout and Aztech-yellow PCB.
Amazing find! I would love to have one of these!
Reply 55475 of 57981, by dionb
Ooh, jealous too. I have the later (ICS and Samsung) Aztech wavetable solutions, but would (almost) give a kidney for the Ensoniq version you snatched 😉
Still, can't complain on the MIDI front - this arrived in the post today:
The attachment PXL_20241214_221201142.jpg is no longer available
Most definitely not what most soundtracks were composed on, but they sound epic on it anyway 😀
Reply 55476 of 57981, by keenerb
Found an estate sale yesterday with some decent finds. Along with a dozen assorted PCI nics/SCSI cards, some PCI-E HBA cards:
ozkYxd0.jpeg in box with manual and accessories. Apparantly a drop-in IDE mirror solution, which is quite interesting!
4EwaeNK.jpeg Supermidro P6SBU sealed with box, manual, accessories.
JfP7bxs.jpeg Nice motherboard. Integerated Yamaha general midi, OPL3-SA/OPL4, and S3 video.
ATMD8o8.jpeg interested CPU package, haven't owned one of those before
Reply 55477 of 57981, by devius
A Socket 370 board with 6 ISA slots??
Reply 55478 of 57981, by keenerb
devius wrote on 2024-12-15, 16:09:
That's exactly what I said. So much room for activities!!!
Reply 55479 of 57981, by dominusprog
Bruno128 wrote on 2024-12-13, 13:58:
dominusprog wrote on 2024-12-11, 13:57:
So I want to buy a K6-2 500MHz CPU, but the seller have two different chips. One is 0016APEW and other one is 0045MPM, is there any difference between the two?
Both made in 2000, it’s exactly the same model and stepping so maybe look at underside photo whether the pins are not bent and take the better of the two.
Yes, I'll keep that in mind.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
