HWiNFO for DOS resurrected !
Reply 560 of 884, by Mumak
crvs wrote on 2021-04-09, 08:10:
Mumak wrote on 2021-04-08, 17:01:
Thanks. Could you please repeat that sequence with debug mode (-d switch) and attach a new DBG file? Maybe it will tell me more why BIOS PnP services are causing such issue.
Of course, here is the result.
Thanks. Looks like you'll need to disable the "Skip PnP BIOS Calls" option in Setup -> Configuration menu.
Reply 561 of 884, by crvs
Mumak wrote on 2021-04-09, 08:20:
This motherboard has a graphical "windows-style" AMI BIOS, and unfortunately it doesn't contain such option.
Diving deeper into the matter, I have found an unofficial M919 guide and another Vogons thread, which build an impression that the "original" M919 BIOS (1995) may not actually support PNP, and other applications may be also confused by this MB. Among the tools for M919, there is a driver PNPFIX.DRV described as the fix for issues with Creative PNP sound cards. After adding it into "CONFIG.SYS", HWINFO reports that PNP is not supported by the BIOS, and "Peripherals info" screen opens flawlessly.
Basing on the screenshots from another thread, newer M919 BIOSes (after 1996) already have PNP support, but since "stock" BIOS chip in this MB is non-flashable I won't be able to verify this in near future.
I'm not sure whether it's possible to implement proper logic with older BIOSes, but it would be nice if the tool could be improved not to freeze or fall over in such cases. M919 boards are somewhat collectible nowadays, due both infamous 'fake cache' and decent performance, so other people may also come across similar behavior.
In any case, thank for your responses, they helped me to identify the root cause.
Reply 562 of 884, by Mumak
crvs wrote on 2021-04-09, 17:27:
This motherboard has a graphical "windows-style" AMI BIOS, and unfortunately it doesn't contain such option. […]
Sorry for not being clear, the option I mentioned above is in HWiNFO.
I'm not sure what exactly is wrong on that system, but it would require much more testing with multiple test builds to determine more precisely the issue and implement a fix for it. My assumption is that the BIOS might be some early attempt to support PnP services, which might be incomplete of faulty.
Maybe if you could send me the BIOS content I could have a look inside if I can see something. You can use the attached tool to capture the actual BIOS content, but please avoid loading the PNPFIX driver in this case so I can see the original BIOS structures.
GETBIOS.COM.zip
493 Bytes
75 downloads
UPDATE: I just had a look at the PNPFIX driver and what it actually does 😀 It disables BIOS write-protection (or shadow BIOS WP) and then clears the "PnP$" identifier in BIOS. That means PnP support in the BIOS is broken and best solution is to avoid it completely. I think there's no need for the BIOS image anymore, but if you could send me a full HWINFO log file + Debug File (you can run HWINFO -r -d) then I should be able to add a workaround for this case.
Reply 563 of 884, by crvs
Mumak wrote on 2021-04-09, 17:40:
GETBIOS.COM.zip
See created files in the attached archive - please note that HWINFO got stuck on "Creating Report File / Plug-and-Play Devices", I had to reboot the machine. Just in case if BIOS image may still be useful to you, I have also included the dump created by GETBIOS, and BIOS backup taken by UNIFLASH.
    ALL_FILES.7z
    136.79 KiB
    55 downloads
Reply 564 of 884, by Mumak
crvs wrote on 2021-04-09, 21:59:
GETBIOS.COM.zip
Thanks. Can you please try the attached build if it doesn't crash now and also recognizes your mainboard?
HWINF613.ZIP
995.54 KiB
60 downloads
Reply 565 of 884, by crvs
Mumak wrote on 2021-04-09, 23:33:
HWINF613.ZIP
Thank you very much!
This build is not freezing anymore, however
  • When I'm running it with "-r -d", it creates reports and immediately terminates - is this expected behavior? It's not mentioned in "HWINFO.DOC"
  • When I'm launching it just with "-d" or without the parameters, both "BIOS information", "PNP information" and "Peripherals information" screens are opening flawlessly. However, PnP is displayed as supported (w/o any remarks), could it be possible to report identified 'inconistencies' of the BIOS (or other hardware)? I wouldn't have imagined that my rack may have a weird issue with PnP if HWINFO had being running smoothly from the beginning, like now. PS: Your CPU errata test is really helpful, BTW.
+Attached application logs for both options, just in case if you may need any other details
    LOG.7z
    6.64 KiB
    57 downloads
Reply 566 of 884, by Mumak
crvs wrote on 2021-04-11, 10:39:
Thank you very much! […]
HWINF613.ZIP
Thanks for the feedback.
Yes, running with -r is expected to automatically create the report file and terminate.
HWiNFO now doesn't use BIOS PnP services on your board to avoid the issue, but it's using its own direct low-level PnP serial isolation to enumerate PnP-capable boards. That seemed to work in the manual mode and detected your ESS PnP-capable card. Not sure why it didn't work in the automated mode tho..
Reply 567 of 884, by crvs
Mumak wrote on 2021-04-11, 12:37:
My pleasure, it's a great tool, glad to help making it even better. If I manage to update a BIOS on this MB, I'll test it again and post here a comment, intrigued if there will be a difference.
Reply 568 of 884, by trixster
Great program! I'm enjoying using it in my 'new' 486DX2-66.
It doesnt seem to detect the 256k cache on my Soyo SY-25P2 motherboard. Report attached
    HWINFO.LOG
    37.38 KiB
    63 downloads
Reply 569 of 884, by Mumak
trixster wrote on 2021-04-28, 10:19:
Thanks for your report. Can you please attach the HWiNFO DBG file (run with -d switch) so I can see more details why it doesn't recognize the L2 cache?
Reply 572 of 884, by Grzyb
Somewhere between 6.0.2 and 6.1.0, HWINFO lost the ability to correctly recognize Celeron 266.
Works fine in 6.0.2, but in 6.1.0+ it's misrecognized as Pentium II:
6.55 KiB
5.25 KiB
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 573 of 884, by Mumak
Grzyb wrote on 2021-05-01, 20:27:
Somewhere between 6.0.2 and 6.1.0, HWINFO lost the ability to correctly recognize Celeron 266. Works fine in 6.0.2, but in 6.1.0 […]
Can you please attach the HWiNFO Debug File (run HWINFO -d) so I can check the details?
Reply 574 of 884, by Grzyb
Mumak wrote on 2021-05-01, 21:08:
Here you are...
    HWINFODBG.txt
    366 Bytes
    53 downloads
Reply 575 of 884, by Mumak
Grzyb wrote on 2021-05-02, 11:52:
Here you are...
Thanks. Does this attached build fix the issue?
HWINF613.ZIP
995.58 KiB
53 downloads
Reply 576 of 884, by Grzyb
Mumak wrote on 2021-05-02, 14:13:
No, it's still Pentium II.
Reply 578 of 884, by Grzyb
Mumak wrote on 2021-05-02, 15:02:
Can you please attach a new DBG file?
Attached...
    dbgnew.txt
    306 Bytes
    60 downloads
