Reply 56000 of 58650, by momaka
- Oldbie
Been a while since I posted what I've been buying... but I guess I've just gotten lazy in that regard.
Probably nothing too interesting for anyone here, as it's mostly Pentium 4 and AMD socket A hardware. Lot's of freebie cheapo ATX cases too, some scuffed and damaged to be considered scrap by most... but I don't mind. Oh, and lots of cheapo gutless PSU's for about $0.50 each (i.e. scrap value.)
Veeb0rg wrote on 2025-02-03, 18:29:I bought a scrap lot off ebay cause I saw something in the photo listings, an AGP Voodoo 5. Sadly it was packed loose with the other parts and now needs some repairs. Anyone know of a source for the 4.7 coils? It will need some work but hopefully can be saved if not by myself then someone else.
These are "PI" (rod core) inductors, so as long as they are not missing any chunks in the middle where the windings are, you can just glue them together (with thin type of glue so as not to increase the gaps between the core pieces) and they should be fine.
Though given the rarity and price of these cards... yeah I can understand about trying to be more cautious and finding proper replacements.
I recall some early Foxconn-built Pentium 4 motherboard used PI inductors like this for the chipset VRM. So these might be compatible.
RetroPCCupboard wrote on 2025-02-03, 14:30:Just received this PC for £50 + postage: […]
Things that stood out to me:
- Motherboard supports PCI, AGP, PCIe.
- Love that blue CPU cooler
- Floppy drive with built in SD/CF card reader
- 128 Bit Geforce 5500 should be good for Win9x
I am planning to use it as a test bench for testing any new hardware that I aquire to make sure that it works. My understanding is that this chipset will support AGP cards of 1.5v or 0.8v, and it should work with most PCIe GPUs up to GTX 580. I think it won't work with dual GPU cards like the GTX 295.
Nice!
That case certainly looks high class on the front for being a cheapie. NGL, the chrome accents are pretty cool. And I like how the various beige components all match in color too. The blue CPU cooler is pretty indeed... almost begging for a windowed case. 😉
As for the 128-bit GeForce FX5500 - that appears like one of the newer China-made builds. If it is, check its electrolytic capacitors. If any have "FZ" printed on their top, you should replace them, as those are know for going out "firecracker-style". See my post towards the end of this thread for more info:
Brand NEW nVidia Geforce FX5500 256MB
Another something I noted: your PSU is a "L&C Technology" one - basically a "bottom-of-the-barrel" Deer/Solytech unit. These are known for being built very poorly, often skipping lots of filtering components inside. So you may want to replace that PSU with something better.
RetroPCCupboard wrote on 2025-02-03, 16:33:Pentium 4 3.0Ghz. I may put a P4 Cedar Mill 3.4Ghz in it. Since I have a few of those CPUs. The motherboard supports dual core P4s, but not Core 2 Duos.
Well, if you do go with a Pentium D CPU, absolutely 1200% replace the PSU then. I know these L&C PSUs all too well, and I can tell you they won't hold up with a Pentium D CPU. Just ask PCBytes.
On that note, you may also want to install the dual 80 mm fans on the back of the case, regardless if you upgrade the CPU or not. P4's produce considerable heat. With just the 80 mm fan from the PSU as exhaust, things ought to get quite "toasty" in 30-40 minutes of use (especially under gaming.)
AGP4LIfe? wrote on 2025-01-26, 03:15:Picked up a nice "Boxed" BFG 7800GS OC. I mean the box is pretty beat up but hey, still a box. 78$ on the bay, which is pretty g […]
Picked up a nice "Boxed" BFG 7800GS OC. I mean the box is pretty beat up but hey, still a box. 78$ on the bay, which is pretty good at least for eBay prices.
Its in great condition its'self though, almost like new. replaced the thermal paste on the core and bridge chip and she sings! Idles at 33*CIts a G71 Core, which is pretty cool. that should mean the OC room is pretty high. It does have the extra shaders, seemingly cut, though riva tuner shows them existing and off. They don't initiate, when selected.
All in all pretty cool! Very Fast.
Very nice find, indeed!
I wouldn't even think to OC that card, though. G71 cores don't do well when they run even a tiny bit hotter, being from the bumpgate era. It's nice to see the GPU run at 33C idle, but what about full load? If you can, try to keep the core under 60C at all times... or better yet, 55C. That should make it last a lot longer. Not sure it would be possible with the stock cooler, though.
Minutemanqvs wrote on 2025-01-24, 18:03:At the local second hand shop something showed up! A Creative labs fan, full-size PCB, and nVidia written on it. Without completely knowing what it was I took it home for around 5€. Apparently it's a GeForce 4 4800 (a 4600 with AGP 8x support)!
It was dusty as hell and at this point I have no idea if it works.
According to wikipedia, it0s supposed to have a max TDP of 43W and I'm a bit suspicious about the small heatsink/fan...
Yeah, that cooler is just marginally better than the stock reference one nVidia used on the TI 4400/4600 series. May want to replace it if you have something better. I mean, look how much space there is on the PCB for a much bigger one. Might as well use it, no? 😀
