Reply 60 of 495, by Mau1wurf1977
I'm currently mucking around with MTRR utilities (Memory type range register) to unlock graphics performance on Intel Pentium 2+ machines.
I have attached what I have found so far. But there are other and I am also interested in older versions which might work better for us.
I'm chasing VESAMTRR: http://www.mdgx.com/umb.htm#VMT
There is a link to a project. The files are all there but it seems they need to be compiled, which is beyond my skills 😒
Also what about utilities to enable MTRRs on AMD or other CPUs?
I got VESATEST going so here are my steps to speed up VGA:
VESATEST 320 200 8 LFB
Will test 320 x 200 resolution 8 bit colours.
It will output a fps and MB/s score.
On a slot 1 machine with PIII-600 with TNT2 M64 I got 756 FPS and 46 MB/s.
VESATEST 320 200 8 LFB MTRRWC
Will test 320 x 200 resolution 8 bit colours and set the registers and enable write combining.
On a slot 1 machine with PIII-600 with TNT2 M64 I got 3315 FPS and 202 MB/s.
BUT the settings don't "stick". It only shows how fast a machine would be be, which is weird. As soon as you run another benchmark after VESATEST it's back to being slow.
FASTVID on the other hand works quite well.
Windows 95 or 98 apparently also enables this and a soft reboot into DOS should retain the settings (easy to test performance). But a hard reset reset these settings. Worth testing if someone has the time!
    FASTV110.ZIP
    1.26 MiB
    113 downloads
    vesatest V146.zip
    148.46 KiB
    116 downloads
    mtrrlfbe V13.zip
    53.24 KiB
    105 downloads
My YouTube channel
Reply 61 of 495, by Mau1wurf1977
To use MTRRLFBE you type
MTRRLFBE VGA WC
My YouTube channel
Reply 62 of 495, by Mau1wurf1977
Something for fun 😀
VIDEO: DOS VGA benchmarking on an Intel Core i5
My YouTube channel
Reply 63 of 495, by elianda
Well the result on this is quite obvious - and the scores doesn't give any reasonable new information.
f.e. the NVidia GPUs since the GTX200 series run VGA as a kind of emulation with a fixed speed. So scores do not reflect CPU or GPU speed at all.
However it would be more interesting if you would explain what Memory Type Range Registers really do and how this can speed up graphics performance. Which CPUs are affected a.s.o.
(K6-2CXT etc.)
Also some analysis until which CPU power the Doom score scaling make sense would be fine...
Youtube Channel
Reply 64 of 495, by Mau1wurf1977
I'm not the right person to do the topic of CPU registers and whatnot justice 😀 I'm more into the practical and fun stuff such as to where can I download it from, what does it do for me and how do I use it. But please feel free to chip in with your knowledge!
VIDEO: DOS VGA benchmarking on an Intel Core i7
Who is going to crack 1000 fps in Quake? 😎 😵
My YouTube channel
Reply 65 of 495, by Mau1wurf1977
Moved a couple of overclocked entries from the stock table to the overclocked table. Elinda did the same with the VM result. I'd like to focus on real computer, not virtual machines or emulators please 😀
My YouTube channel
Reply 66 of 495, by Geoman
On a Phenom II I get 500.0 FPS - seems to be the upper framerate-limit of that superscape benchmark...
Aside from that, everything is whirling around like crazy - exactly as in the Core i7 video on YouTube.
IBM Aptiva 2168-931
Reply 68 of 495, by Geoman
I just ran the benchmarking-suite on my Octane2, running on SoftWindows 95's DOS-Mode. (=pure Emulation X86->MIPS)
The Superscape-thingie hangs at the splash-screen 🙁 Everything else runs fine, but slow...
@Mau1wurf1977: Perhaps we could add a new sheet for DOS-Emulation.
    63.75 KiB
    10.96 KiB
    51.41 KiB
    11.96 KiB
    7.59 KiB
IBM Aptiva 2168-931
Reply 69 of 495, by Mau1wurf1977
Geoman thanks for the suggestion and contribution. I will add a page 😀
My YouTube channel
Reply 71 of 495, by Mau1wurf1977
Geoman wrote:
Cool! Thanks! 😀
Hehe I shall do a run in DOSBox and see what I get 😀
My YouTube channel
Reply 72 of 495, by sandmanx
Got a pair of fairly obscure 486 DX2 80s on deck that I hope to get to tomorrow.
file.php?id=13454
    98.36 KiB
    No downloads
Reply 74 of 495, by sunaiac
Very nice topic Mau1wurf, good to compare our oldies to spot a tuning problem quickly 😀
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 75 of 495, by Mau1wurf1977
Chart Version 1.0
Guys, terrific effort!
We have amassed over 150! results so far! I can't imagine what this project will look like in a year 😀
But there is still a lot to do. We have a HUGE need for Pentium 4, Core 2 Duo, anything from Cyrix, UMC, TI, more from AMD, S754, S939, AM2, AM3...
Here a chart of our current progress:
My YouTube channel
Reply 76 of 495, by Skyscraper
So if you are building a retro DOS system and want an avarage FPS of 37 you would need a Pentium 100 or a Pentium 3 850...
Some information gets lost in that chart 😁
Reply 77 of 495, by Mau1wurf1977
Well hopefully one realises the outliners and applies a bit of common sense 😀
Plus one can then dig deeper, taking a look at the configuration of that machine or contacting the tester. Or I could remove outliners myself 😀 The bulk of data will organically bring out the truth 🤣
It's early days in the project, lots to learn and discover. The impact of FASTVID / MTRRLFBE for example. And how much faster AMD graphics cards are on newer machines.
EDIT: That machine has an ISA video card 😀 That explains it.
My YouTube channel
Reply 78 of 495, by Geoman
...but my AMD Phenom II is only 4th place :'(
--joke 😉 *g*
Thats a cool chart indeed!
And it is interesting to see for example, that K6-III+ based systems score so differentially - it shows that the MoBo, GFX & memory combinations have a huge impact on performance.
IBM Aptiva 2168-931
Reply 79 of 495, by Mau1wurf1977
Hehe AMD rocks under DOS 😀
Totally! Unlike the reviews back in the day, when you got 1 score and that was it. This chart shows a nice spread with certain system. Whereas with a P3 for example they are all grouped quite tightly, indicating that with a BX440 system it hardly mattered what you got, they all perform very similar.
My YouTube channel
