Reply 60 of 194, by Kamerat
- Oldbie
Added results for a Pentium II @ 100MHz with cache disabled, looks like 3DBENCH show's erroneous result at this speed, no way that looks like 57,5 fps.
Thanks for adding the results! Do you remember if you used 3dbench 1.0c or 1.0? Version 1.0 is supposed to scale better with slower cpus.
Updated the 3DBENCH result with the 1.0 version instead of 1.0c, looks more realistic now with 2,3 fps.
I ran the pcp and 3d benches on a pentium 166 with pci voodoo banshee, then on an agp tnt2 with a p3-700 underclocked to 233. The scores were something like 5-10* higher, about what I expected due to AGP, so I put in a pci s3 trio and actually got a similar result on the 3d bench. Why is this? Surely the 3d bench wouldn't be taking advantage of the s3's meager 3d capabilities due to being run under real mode dos?
wrote:I ran the pcp and 3d benches on a pentium 166 with pci voodoo banshee, then on an agp tnt2 with a p3-700 underclocked to 233. The scores were something like 5-10* higher, about what I expected due to AGP, so I put in a pci s3 trio and actually got a similar result on the 3d bench. Why is this? Surely the 3d bench wouldn't be taking advantage of the s3's meager 3d capabilities due to being run under real mode dos?
3DBench doesn't use 3D acceleration. Despite its name, it is a 2D performance benchmark, which the S3, Banshee and TNT2 are all very good at.
wrote:wrote:I ran the pcp and 3d benches on a pentium 166 with pci voodoo banshee, then on an agp tnt2 with a p3-700 underclocked to 233. The scores were something like 5-10* higher, about what I expected due to AGP, so I put in a pci s3 trio and actually got a similar result on the 3d bench. Why is this? Surely the 3d bench wouldn't be taking advantage of the s3's meager 3d capabilities due to being run under real mode dos?
So the speed disparity with equal video cards must be due to having a p3 at 233, even with only a 77 mhz difference over the 166?
wrote:So the speed disparity with equal video cards must be due to having a p3 at 233, even with only a 77 mhz difference over the 166?
Yeah. 77Mhz doesn't sound like a lot, but 233 is over 40% faster than 166. I'm not sure how a P3 and P1 compare clock-for-clock, that's another variable.
wrote:wrote:So the speed disparity with equal video cards must be due to having a p3 at 233, even with only a 77 mhz difference over the 166?
I had an idea for artificially limiting cpu speed in windows, simply adjust the power management so that to processor state is a certain percentage of whatever speed you want. However I take it you've made this utility since most of what we're using it for will not run under xp and later? (xp being the first o.s I'm aware of that you could limit clock speed)
wrote:wrote:wrote:So the speed disparity with equal video cards must be due to having a p3 at 233, even with only a 77 mhz difference over the 166?
I did not make Setmul. Forum member gerwin did. 😀 It is a compatible with DOS, 95, 98 and ME only. Here's more info on it:
SetMul - Multiplier control for VIA C3 / AMD K6+7+8 Mobile / Cyrix 5x86
For my purposes, it is for a DOS PC, to slow the system down to play older speed sensitive games.
Added an Intel 486DX2-66. Used Setmul to disable L1 and BIOS to disable L2. Disabling L2 did not add significantly to the slowdown. With cache disabled, the CPU is performing like a 20Mhz 386.
Interesting. Not much slower than a K6-2 on 100% cache slowdown.
Not documented on the chart, but the turbo switch drops speeds to the equivalent of a 486-18. Now to see if the turbo switch in conjunction with disabling caches can yield some other speed zones.
When i turn off L2 Cache my K6-3 hangs at the BIOS Screen showing Summary (Floppy Drives, Memorysize, Ports..)
I think this is because of l3 Cache. 😳
wrote:When i turn off L2 Cache my K6-3 hangs at the BIOS Screen showing Summary (Floppy Drives, Memorysize, Ports..)
Do you have BIOS timings tweaked? I noticed on my 486, if I got really aggressive with memory and cache timings, the system would work at full speed but would lock up when I disabled cache! I expected the opposite. 🤣. At any rate, I don't know if this has anything to do with your K6-3, but it's worth a look to set BIOS timings to default and try again?
Thanks!
On my p2-350 underclocked to 233, if I run topbench it wildly switches between saying it's a p200 and a k5 116, with one cache on and one off. What does this mean?
wrote:On my p2-350 underclocked to 233, if I run topbench it wildly switches between saying it's a p200 and a k5 116, with one cache on and one off. What does this mean?
Some older DOS benchmarks get really confused when you do things like disable caches, underclock, or run them on CPUs much newer than the benchmark. I remember topbench being one of those benchmarks.
I wouldn't worry about it, just run a range of benchmarks and focus more on the ones that make sense. I put more weight on real game benches, like Wolf3D, Doom and Quake.
My doom realtics are varying wildly from the equivalent systems on the list, and iirc even with the same cpu with no cache disabled. Topbench reckons the cpu is the same speed though. Could it be my fsb or ram speed/amount/type? The 3dbench was within 15% or so of a "real" system.
wrote:My doom realtics are varying wildly from the equivalent systems on the list, and iirc even with the same cpu with no cache disabled. Topbench reckons the cpu is the same speed though. Could it be my fsb or ram speed/amount/type? The 3dbench was within 15% or so of a "real" system.
What are the rest of your system specs? Motherboard, graphics card, cpu, motherboard cache, etc. Also post your scores with cache enable and disabled.
Each run is randomly different?
Some corruption creating a random bottle neck in performance.
Try different RAM and make sure you don't go above the cacheable amount of the Motherboard.
If it doesn't solve the problem try changing the CPU.
As you disable the Caches the CPU relies more on the RAM each level of cache you disable.
