Reply 60 of 148, by luckybob
- l33t++
video editing, CAD, Running two things at once.
If I would use it for retro CAD stuff, would it make more sense to go all the way to a Slot 2 PC?
wrote:Ok! Good to know!
So bottom line, what would a dual Slot 1 PC excel at?
At giving luckybob orgasm of course. 😜 Actually, quite a few other vogoners too!
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
wrote:wrote:Ok! Good to know!
So bottom line, what would a dual Slot 1 PC excel at?At giving luckybob orgasm of course. 😜 Actually, quite a few other vogoners too!
LoL, some of the stuff I got would certainly do the job. /hides everything
So, is a Slot 1 PC worth it?
its no different than a socket 370.
wrote:its no different than a socket 370.
Pretty much this
Well then, I'll probably go with Slot 1 since it is so different and cool. I think the CPU cartridge idea was a good one, since more can be put onto the cartridge itself, thus saving space for other chips on the motherboard. Also, it makes switching CPUs a breeze, and it takes up less space on the board.
If you want to make it harder and cooler, look for slot-A instead. My Voodoo2 setup is an AMD 1ghz slot A setup. Runs fast. All I need to find is a goldfinger device and Alpha heatsink.
I've looked at slot A. I think for my Athlon build, I will choose Socket A. If Slot 1 and Socket 370 are really that similar, I won't build a 370 PC.
wrote:I'm willing to bet he means PCI slots. V2's are pci only after all.
Ooh! What is THAT gorgeous hunk of AGP power?
That is a slab of fiberglass, silicone, and copper. It sells for several hundred dollars.
wrote:So if I understand it correctly: 3Dlabs - Pentium II FireGL - Pentium III Quadro - Pentium 4 […]
3Dlabs - Pentium II
Quadro - Pentium 4
Not so easy. There's quite a difference between a 3Dlabs 300SX based card (late 1994), 500TX (1996) and MX (1997). After this were the 3Dlabs Oxygens (before was the Dynamic Picture Oxygen V192, DP was later bought by 3Dlabs). Later, after they've acquired the workstation business from Intergraph, were the Wildcats.
FireGL is also a broad term. There were many FireGLs, on very different chipsets. There were even just "Fire" cards, before they could do OpenGL (Fire and the first FireGL, based on 3Dlabs 300SX, were manufactured by SPEA, later bought by Diamond).
The first Quadro was released when Pentium IIIs were popular, before Pentium 4 was sold. It was the ELSA GLoria II (had one in that days), SGI also had also their Quadro based VPro VR3 cards.
Of course there were many other OpenGL workstation cards in the 90s'. Intergraph was the PC high-end of 3D graphics. E&S did some nice systems (never seen a Freedom Series subsystem). OKI, NEC, Lockheed Martin, AccelGraphics and many others, even SGI had their PC-like Visual Workstation (a Quad Pentium III Xeon monster).
So, if I wanted to get the craziest, most powerful 2005 era workstation, what would I need? Just out of curiosity. Also, what would be the most powerful graphics card I could get on a dual cpu slot 1 Pentium 3 motherboard?
2005? Thats late P4 era. Google the Asus ncch-dl motherboard, put 2x 3.8ghz irwindale processors. The options are endless and quite frankly boring.
wrote:2005? Thats late P4 era. Google the Asus ncch-dl motherboard, put 2x 3.8ghz irwindale processors. The options are endless and quite frankly boring.
Nope. 2005 is AMD. Dual Opteron + GF6800 SLI FTW! Look at the God Box: http://arstechnica.com/gadgets/2005/04/system-guide-200504/
Pci-e machines dont count.
wrote:Pci-e machines dont count.
Challenge accepted. Iwill DK8N (NVIDIA nForce3 Pro 250) with dual Opterons and AGP! http://www.burningissues.net/hard/DK8N_review/ Not sure if there were more Dual Opteron nForce boards with AGP.
