Reply 60 of 72, by Mamba
- Oldbie
wiretap wrote on 2021-02-04, 18:30:@pshipkov -- that may be the case with incompatibility for some odd reason. The chip does get warm, but no post. As far as the little board, it is pretty sturdy. I pulled jumpers off and put them on with one hand, just holding my thumb on the motherboard connector side. It does lean a little bit, but it doesn't fall of the board and has a good amount of friction-fit.
@Mamba -- I didn't test that, since this mod adds the 4th row of jumpers which specifically takes advantage of the 9250 clock gen. The 4th row would not map to anything on the old one.
Yes I can understand.
So it is not usable even if no pin has been jumpered on the 4th row?
