Reply 80 of 123, by sdz
Some updates:
1. I got coreboot and SeaBIOS working on the machine with the V4 MXM card as the primary card. It's a long story, but basically I moved the VGA ROM execution from coreboot to SeaBIOS and axed the iGPU so that it isn't detected by SeaBIOS (which was way harder than I thought it would be) during init.
Installing XP fails with "System is not fully ACPI compliant". I found a few ACPI related issues and fixed them, but it still fails with that error.
98 freezes shorty during startup.
DOS and Linux work fine.
2. Managed to finally assemble a second card/laptop. Found a bug that wasn't present on the first card/laptop, most likely due to silicon variation and whatnot. Fixed that.
I'll probably assemble 3-4 more laptops/cards, just to be sure that everything is fine.
3. Found some FIFO related issues on the FPGA side and fixed them.
4. 1280x960 now works thanks to the timings provided by @3dfx_fan here: Lost Joker 2 - image shifted to the right
I'll start assembling all the documentation/files for this project, and if the next few laptops/cards work fine, I'll publish everything. Haven't tested the latest FPGA code on the eDP variant, but it likely still has issues.
Also made this in the meantime, currently testing it, but it seems to work fine:
