First post, by Aui
Hi everyone, found a large full size ISA card in a 486 era desktop. Can anybody tell me what that is and what it does. I tried to search for some of the labels and chip numbers, but I still cant figure out what the thing does as a whole (and how and for what I could use it today ). Thanks
    204.18 KiB
    331.54 KiB
Reply 1 of 5, by dominusprog
It looks like a property industrial controller of some kind.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 5, by Grzyb
https://ui.adsabs.harvard.edu/abs/1997SPIE.30 … ..327O/abstract
"System has an advanced analog-digital controller"
The patent numbers also point to "Head-Mounted Display With Eye Tracking Capability".
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 3 of 5, by PC Hoarder Patrol
It's an interface board used in opthamology for tracking eye movements...
"Eye movement record showing horizontal and vertical traces of the right (R) and left (L) eyes with the Ober-2 system. Patient no 2 with only horizontal traces shown. The record showing a jerk nystagmus with a SPI (slow phase exponentially increasing velocity) waveform with a superimposed foveating saccade (arrow). Horizontal bar, 2 degrees; vertical bar, 200 ms."
Reply 4 of 5, by Aui
Ah thanks a lot for the skillful detective work. So there may be even some additional (medical?) hardware included. It seems I wont be using this card then...
unless... HUD with eye tracking in Flight Simulator 5.0...
Reply 5 of 5, by PC Hoarder Patrol
Aui wrote on 2024-04-18, 08:55:
Someone had a similar idea 😀 (your's is cited for reference) - https://stars.library.ucf.edu/cgi/viewcontent … context=patents
