First post, by prego
Hey there,
I fairly new to the retro PC game. I worked in a computer storeat the end of the 90s and know some things. Already had my shot with Amigas 😉
But now I got my hands back on old pc Hardware having fun tinkering again. Among other things in real life I develop open source PCBs and sell them through my small company. So some tools regarding electronics work are present.
Got my hands on a Chaintech 6VTA2 Board, incluning a Pentium III 500: https://theretroweb.com/motherboards/s/chaintech-ct-6vta2
The sticker on the BIOS chip cleary states it's a 6VTA2 albeit the board looks more like an 6VTA3 (https://theretroweb.com/motherboards/s/chaintech-ct-6vta3).
It is scratched a little as I had to read the chip type - see photos.
So, I wanted to update the BIOS using the files from the retroweb. Installed was the 07/07/99 version and I tried to update to 12/18/2000 using awd899.exe. The board worked withought any problem before in Win98SE and (free)DOS.
I backuped the existing bios beforehand and flashed the new one. Only when I restarted the machine I saw that there were some blocks with write fails (red). But i was too late.
After a reboot the mainboard is stuck at a black screen. Currently no pc speaker attached, so I don't know if it is beeping. Most likely it is...
Well, I thought, no worries and dug my TL866II MiniPro out, blanked the MX29F00NT-12 (120ns) and wrote the backup I made before.
But no luck... still a black screen. Maybe the flash chip is done? There were no errors on verify on the MiniPro...
Then I tried the newest BIOS from retroweb, also no luck.
So, I ordered some AT27C020-90PU (90ns) which should be compatible, are they?
Burned the backup, burned the newest .bin - no luck.
As you see I'm stuck and would be very happy if someone can point me in a direction to fix this. Obviously I understand something wrong.
Should I try the minipro on real Windows hardware? Currently using it on Win11 ARM on my M1 MacBook in UTM (https://github.com/utmapp/UTM).
Cheers and thank you,
p
    511.06 KiB
    6VTA2 Board
    345 KiB
    6VTA2 Bios Chip
Reply 1 of 1, by prego
Found it!
I forgot to load the .bin file with "Clear Buffer with 0xFF" option. Dang!
Could someone clarify on this? See screenshot.
Used the newest .bin on the origirnal MX29F002NT for flashing and all is working now. Cheers!
Obviously my saved .bin was only 128kb and not 256kb as needed. So something wrong there.
AT27C020-90 is working too.
