First post, by winuser3162
Asking to hear any funny stories (if any) or thoughts of people liquid cooling parts that don't require liquid cooling in the slightest. i wonder if anyone has ever tried to rig up a custom loop on something like a pentium 1, 486, 386 or 286. I would assume that during the early to mid 1990's, liquid cooling must have been extremely niche if not non existent.
Imagine a custom loop on a motorolla 68000, and intel 8008 or even a 4004 just for the hell of it. what a thought!
1. Pentium 2 400, Aopen HX45, Aopen AX6BC, 256MB RAM, Voodoo 2 16MB 2x, SiS 6326 AGP, SB AWE64, floppy super disk drive
2. Pentium 200 MMX, Diamond 3d V1, S3 Virge, 60MB RAM, SB Vibra 16, Aopen AP5VM
3.SGI octane, R12K 300 x2, MXE graphics, 2GB RAM,
Reply 1 of 25, by debs3759
The oldest water cooled system I've seen online (too long ago to remember where) was a 486. Can't remember any details, but I think prior to Socket A all loops used custom blocks. None of the professional quality stuff we see these days 😀
Reply 2 of 25, by winuser3162
debs3759 wrote on 2024-04-19, 20:50:
unless you are planning on doing some record breaking OC, is there any other benefit to watercooling a 486 aside from general temperature control?
Reply 3 of 25, by debs3759
I would imagine that some 5x86 might benefit from WC to overclock to 200. Never really thought about it though, I just remember reading some article.
Reply 4 of 25, by BitWrangler
It was an idea that got tossed around when "shooting the shit" in overclocking circles for several years in the 1990s, there wasn't really a necessity for it until we were forcing CPU into the 30W plus regions. The initial more serious experimentation with it came in late 98 or 99ish with attempts to get mendocino celerons to break through the 650-700mhz region, and were replicated by some in the Athlon camp to get to 1Ghz before Intel or AMD officially did.
There is a bit of a memory hole for the two years where amateur watercooling was making it's biggest strides, due to incomplete web archival from archive.org until later noughts, and forums being on server side perl scripts and custom software rather than the now ubiquitous vbulletin and simple machines forum software etc. Also for "web 2.0" a lot of sites basically had all their old stuff wiped offline and started fresh.
There are still some articles on overclockers.com from the end of the amateur era, then there was a bunch of custom parts available commercially from small startups, and it was still pretty much roll your own with combinations of those, then the larger cooling names began introducing products, and then we were into the complete systems and then on to sealed AIWs.
Anyway, if you want a "toy" watercooling setup for 1.5Ghz and lower, put one on you K6-III, there's a surplus place got a bunch of "Silent Stream" kits cheap that weren't well reviewed for high performance use (2Ghz plus) in the day... https://www.a1parts.com/surplus/index.html
Reply 5 of 25, by megatron-uk
I bought a water-cooling kit for an Athlon XP system.
In reality it was a really crappy water block with two push on barbed tails, some tiny diameter silicone hosing, a 'radiator' barely big enough for an 80mm fan to fit on it and a tiny fishtank pump.
It was genuine crap, but at the time I thought it was ace, even though I was constantly topping it up because the water would evaporate... From somewhere!
Finally I then got the bright idea to run the pump from a bucket full of water so that it wouldn't heat soak so quickly.... Yes, it was so crap that it could not cope with the single XP processor.
https://www.target-earth.net
Reply 6 of 25, by BitWrangler
Pumps were a huge problem in the early days, it was as bad as; reliable/high-flow/affordable ... pick ONE out of three.... though also nobody really really knew what all we needed and were still establishing parameters as it were, then there was a line of pond pumps that proved quite favorable for a while, then there were commercial solutions.
Reply 8 of 25, by BitWrangler
If you've got printed circuit board etching fluids, you can just cut a block of copper to size and eyedropper etchants and rinse in a bit of a pattern, then use a plate with drilled and tapped holes for fittings on top. ... you can probably do it electrolytically as well, mask off the bits you don't want eaten and give it current until it's deep enough... nothing with too fine a wall though.
However, for all the cooling a 286 or 386 needs, then just hardware store brass fittings with flat sides are probably adequate as the whole "block"
Reply 9 of 25, by winuser3162
Shponglefan wrote on 2024-04-19, 22:53:
If I had a milling machine, I'd be so tempted to do an utterly ridiculous water cooling setup, like on a 286 or something nonsensical like that.
i hope someone tries to overclock the crap out of a 286 with some insane cooling solution like that someday
Reply 10 of 25, by BitWrangler
One of the reasons that watercooling didn't really get going until we were in the 100s of megahertz is it's not really the CPU cooling holding you up. Pshipkov has some peltier experiments with DX5 5x86 buried in his 3+3 Battlestations thread though if you wanna know what that gets you, assuming chilled water would do about the same.
Reply 11 of 25, by winuser3162
BitWrangler wrote on 2024-04-19, 23:20:
i will have to check that out. is it possible to overclock components other than the CPU or GPU such as a network adapter, sound card, chipset ect? ive heard of monitor overclocking for sure and i think i read something awhile back about people water cooling their monitors. id love to see a watercooled ethernet adapter or soundcard for shits and giggles one day. water cooled powersupply even? that might end in disaster...
Reply 12 of 25, by Disruptor
Well, somewhen in spring 2002 I have been on a big LAN-party (BYOC - bring your own computer) in Locomotive hall, Göttingen, Germany, with over 2000 participants. Göttingen is likely in the center of Germany.
It started Friday late afternoon and should end somewhen on Sunday.
There have been servers from the staff and for some games non-staff gameservers in the service area.
Somehow one of the non-staff servers has had a water cooling system.
Warning. Adult content. Not for minors.
However, it happened the worst thing that could happen - that water cooling had a leak.
And it managed to break the electricity of that area Friday in the evening, just when the tournaments should start.
It took more hours to find electricians helping them to fix the problem - it was Friday evening!
I honestly do not remember when they even started to work.
It was so embarassing for the staff.
People got upset. I wanted to compete in StarCraft tournament. Wtf, I don't need a game server!
Somewhen in the late night it still was not fixed.
Alcohol would not have been a good idea, so no free beer.
So the staff managed to get 2 gogo girls to make a striptease show for the audience.
There even have been minors there! (16 and 17 years)
As far as I remember it took 17 hours to get that area back online.
https://goest.de/LAN.htm (in German, with pictures)
Reply 13 of 25, by Lylat1an
I once saw a stock Intel 115x cooler that had a copper tube going through it and fittings on the ends.
Also, not liquid cooled but made me laugh:
CPwPHpRUYAAw_e8?format=jpg&name=900x900
Reply 14 of 25, by BitWrangler
Lylat1an wrote on 2024-04-20, 03:24:
Yah one of my "shitty waterblocks" from around turn of millennium was a broad finned sink that I hammered down malleable 1/4 inch copper pipe down into, making it conform to bottom and sides. Another one was one of those early screw down into base pentium sinks, with short fins, encapsulated into a slice of PVC pipe. Testing on K6-2 with windshield washer pump and automotive heater cores was a bit inconclusive because temperature measurement was not integrated in boards I was using or CPU, and it was a case again of it not really being cooling limiting the overclock, so they didn't really gain anything.... plus the pump whine was worse than any decent HSF so no noise benefits.
Reply 15 of 25, by Dan386DX
There was a Core2 Duo system on eBay the other day with water cooling, it appeared to have been built like that by some OEM.
Not sure I’d trust it not to leak after 20 odd years.
90s PC: IBM 6x86 120Mhz. 128MB/6GB. ATI Rage Pro 3D.
Boring modern PC: R9 3900X, RX 7800XT. 32GB/1TB.
Fixer upper project: NEC Powermate 486SX/25. 16MB/400MB.
Reply 16 of 25, by RandomStranger
I've read an article in the early 2000's about someone making a water cooling system with a car radiator. The pump was also something never meant for water cooling a computer. I think it was something intended for garden ponds. I don't know for which platform.
The X800 XT I got a couple of years ago came with an aftermarket water block which I found funny since it has about the same TDP as a GT730 which is often cooled passively. And fair enough given the size of the water block, it could keep the X800 below 50°C temperatures idle for over an hour. Without water.
Reply 17 of 25, by cloverskull
Slightly OT here but I still have a G5 PowerMac and the liquid cooling systems on those are notoriously bad for destroying a lot of computers. This has given me a healthy fear of liquid cooling to this day 😜
Reply 18 of 25, by megatron-uk
winuser3162 wrote on 2024-04-19, 23:15:
The problem with over locking 286 (and 386 for that matter) is the lack of on chip cache.
The speed of the 286 and 386 systems are heavily tied in to the speed of their memory bus too, which means that you also have to over clock the hell out of the supporting chipset. You don't get a significant speed up from a faster CPU itself since you can't feed it instructions any faster than you could at stock speeds.
As soon as you are able to decouple the CPU from directly talking to memory (even with a tiny amount of cache like with the most basic 486 designs) then your speed increase is no longer tied to that of the memory bus. Just look at the spread of clockspeeds from earliest to latest designs with the 286 (6? 8? to 25) and 386 (16 to 40) compared to the 486 (16 to 133 and higher).
Granted some of that came from process improvement allowing the higher frequency, but by decoupling the memory from directly interfacing at clock speed, and integrating on chip cache, the 486 was able to benefit from much higher clock speeds than it would have if it was talking directly to memory directly (not that anyone had the technology to make 133mhz memory or data bus interfaces at that time anyway!!!!).
Reply 19 of 25, by megatron-uk
I'd love an absolute screamer of a 286 as much as anyone else who owned one at the time (somewhere between 25 and 30mhz is the stability limit on the best boards I have found)... But realistically none of the supporting memory controllers (or memory itself) will go much higher than that... so it's really a hard wall you run into.
If someone designed a 286 system from scratch, with an off chip cache (putting aside the fact the 286 design has no cache control built in, so it would probably be best making the memory controller transparently do the caching for you) then you could start to look at much higher speeds.
An FPGA design may be the way to go here.
