First post, by limpozzyfan
How can I get this game to work on Dosbox?
I have mount the cdrom drive how do I play the game?
What game!!!! ? Your post is too vague. 😠 😒
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Star Trek Deep Space Nine Harbinger
Just mount the 1st CD properly, switch to that drive, install the game, and run it:
mount d f:\ -t cdrom -ioctl(assuming F: is your cdrom drive)d:install(autodetect SVGA - it should detect an S3 card)(choose Sound Blaster 16 or AWE32 for digitised sound)c:cd \ds9harbds9
You'll want to use the dynamic core and increase the cycles to something like 50000. I also recommend you use a recent CVS build of DOSBox.
It wont install why?
It doesn't like you probably.....
We won't know why it won't install unless you give us an error message or something.....
I've played it in DOSBOX. It works pretty well. You should look up DOS32A and replace the dos4gw.exe with dos32a.exe (rename dos32a to dos4gw). This will make the game more stable and a bit faster.
Otherwise just pick SB16 for sound. port 220, irq 7, dma 1. Or any Sound Blaster for that matter.
limpozzyfan,
I replied to your thread in the DOS forum without seeing this one. Please do not crosspost. This is why.
I have tried to install it using dosbox but it keeps saying system not found why?
*** Remerged everything and rewrote thread's title a little ***
*** Moved to DOSBox Games/Apps. too ***
Intel i7 5960X
8 GB DDR4 (2100)
Have you also actually mounted a hard drive directory as your DOSBox C drive?
My site: Ramblings on mostly tech stuff.
