First post, by Lylat1an
I'm looking for a free alternative to WinImage that can write floppy disk images in Windows 10.
I'd like one that's truly free: As in doesn't have a trial version, nag me to register, nor have any other limitations.
Reply 1 of 6, by Grzyb
There's dd.exe in Cygwin port of coreutils...
dd if=somefile.img of=\device\floppy0
Edit:
I tried it in Windows 11 with a USB floppy drive, and the following worked:
dd if=somefile.img of=/dev/fd0
But it was slow.
For good performance, larger block size is necessary, eg.:
dd if=somefile.img of=/dev/fd0 bs=65536
Unfortunately, Windows is retarded as usual, and keeps creating the "System Volume Information" directory on the diskette 😜
I don't feel like fighting it now, luckily I have DOS and Linux machines at hand...
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 2 of 6, by Jo22
Lylat1an wrote on 2024-04-24, 03:07:
"Was nichts kostet, ist nichts wert" 😸
(What Costs Nothing Is Worth Nothing)
Reply 3 of 6, by Lylat1an
Jo22 wrote on 2024-04-24, 14:28:
Then what program would you advise using?
Reply 4 of 6, by elszgensa
The most expensive one you can find will be best, obviously.
In unrelated news, the Greaseweazle software is free, so there's no way that thing's ever gonna be useful for anything. No way at all.
Reply 5 of 6, by Lylat1an
elszgensa wrote on 2024-04-24, 15:12:
I hadn't considered using that since I don't have their hardware, might it work with a generic USB floppy drive?
Reply 6 of 6, by Grzyb
Windows isn't free, but it somehow doesn't make it good for imaging diskettes...
When dumping a diskette to a file, it's always a good idea to write-protect the diskette - no problem then.
But can't write-protect when doing the opposite, and:
- Windows 9x writes the "IHC" signature in the boot sector
- modern Windowses create the "System Volume Information" directory
