First post, by theelf
Im building a cyrix 5x86 100mhz PC and i want to compare some benchs to know how good/regular/bad is my setup!!
Someone with same cpu to give me a hand?
thanks!
Reply 1 of 10, by Dan386DX
theelf wrote on 2024-04-25, 22:49:
thanks!
Ye olde Ultimate 486 Benchmark would be a good place to look, the 5x86 is involved there, since it's technically a faster 486. Consistently near the top of the pile, one of the best CPUs to have graced socket 3.
90s PC: IBM 6x86 120Mhz. 128MB/6GB. ATI Rage Pro 3D.
Boring modern PC: R9 3900X, RX 7800XT. 32GB/1TB.
Fixer upper project: NEC Powermate 486SX/25. 16MB/400MB.
Reply 3 of 10, by appiah4
I have one running at 120 and can run any bench you need.
Reply 4 of 10, by waterbeesje
Cyrix 5x86 100GP here.
Motherboard Aquarius MB4DUV (UMC UM8496/8498)
32MB fastpage 60ns
256kB cache
Diamond Stealth Trio32 VLB
Quantum Bigfoot 4,3GB
Ms Dos 7.1 (from Windows 98SE)
Some Cyrix program to enable hidden switches
Ran Phil's dosbench suite.
Pc player 320x240: 13,1 fps
Doom 640x480: 2126 realtics
Quake 320x240: 10.0 fps
Speedsys CPU : 52,24, ram 34,48MB/s
This particular motherboard isn't the fastest around, but it gives you another comparison.
Stuck at 10MHz...
Reply 5 of 10, by theelf
Hi guys! thanks reply, i will post my results, will love to compare to others with cyrix 5x86
I did this benchmarks, but i will be happy to try another ones
3Dbench 1.0 90.9
3DBench2 85.2
Doom - Shareware 1.9 fullscreen NO borders, no sound
doom -timedemo demo3 -nosound = 2134/1679 = 44.4fps
doom -timedemo demo1 -nosound = 5026/3950 = 44.53fps
Quake v1.06 shareware 320x200 fullscreen NO borders nosound nocdaudio (quake -nosound -nocdaudio)
timedemo demo1 = 11.4fps
waterbeesje wrote on 2024-04-26, 10:27:
Cyrix 5x86 100GP here. Motherboard Aquarius MB4DUV (UMC UM8496/8498) 32MB fastpage 60ns 256kB cache Diamond Stealth Trio32 VLB […]
32MB fastpage 60ns
256kB cache
Thanks!
PC Player 18.9
PCplayer 640x480 6.9
Speedsys CPU : 55,92, ram 40,88MB/s
Dan386DX wrote on 2024-04-25, 23:17:
thanks!
Hi! yes, i try to read, but is too much info... i want just a fast compare to other cyrix, with same parameters. I tried to read the pdf, but i feel lost with what parameters he use with doom, quake, because i get very different results
Reply 6 of 10, by Dan386DX
@theelf, in the thread I linked, just scroll down the page a bit and you will find some comparison charts 😀
Reply 7 of 10, by appiah4
Cx5x86-100@120MHz with several hidden features turned on, Riva128 PCI
3DBench 1.0c 76.9fps
Chris's 3D Bench 91.3 pts (54.7fps)
PC Player Benchmark 21.7fps
Quake Shareware 320x200 15.6fps
Norton SysInfo 316.8
Speedsys 63.7
NSSI 63345 Dhrystones, 23370 KWhetstones
Reply 8 of 10, by theelf
appiah4 wrote on 2024-04-26, 19:07:
Cx5x86-100@120MHz with several hidden features turned on, Riva128 PCI […]
Speedsys 63.7
Hi!!! thanks for testing
One question, the Quake benchmark is with fullscreen or the one from chris pack that have a small screen. Because if is second, i get 13.6 fps
If this one i get 13.6
The attachment quake00.png is no longer available
I ask you because other benchmarks, i get similar results, like Chris's 3D Bench i get 87.2 (52.3fps)
Dan386DX wrote on 2024-04-26, 18:59:
Thanks! yes i already check all 15 pages before, in fact, was one of the threads i use to compare my cyrix before decide open this one, to have less but a more direct results
Reply 9 of 10, by appiah4
theelf wrote on 2024-04-26, 20:32:
Hi!!! thanks for testing […]
Speedsys 63.7
My Quake score is from the PCL DOSBENCH suite, and has the status bar at the bottom same as your screenshot.
Reply 10 of 10, by theelf
Speedsys 63.7
thanks! i get curious about overclock the 5x86 to 120mhz like you did, sadly i need to disable L2 cache to be stable, but at 120mhz even without L2 , i get this results
3DBench 1.0c 100.7fps
Chris's 3D Bench 100.6 pts (60.4fps)
PC Player Benchmark 22.0fps
Quake Shareware 320x200 16.6fps
Norton SysInfo 380
Speedsys 67.25
Doom 2134/1425 = 52.4fps
