First post, by zwrr
Hello everyone,
I got several Super IO cards(Re: Bought these (retro) hardware today), one of them I can't find any information on the internet, there is only the string of CY-573-V1 on it, no other information, can anyone help me get the jumper setup instructions for it?
428.08 KiB
423.08 KiB
486DLC-40, 386-VC-H, 32MB, GD5429, ES1868F
X5-133, HIPPO-15, 32MB, Riva 128, ES1868F
5x86-120GP, SYL8884, 32MB, Trio64V+, ES1868F
Pentium MMX-233, T2P4, 128MB, TNT2, SB16
Tualatin-1.4G, 694X, 512MB, G400, Voodoo2, SB AWE32
Reply 1 of 1, by weedeewee
just going by the ISA pinout & photos
JP5 clearly IRQ selection
position 8 is connected to IRQ7
position 7 is connected to IRQ5
position 6 is connected to IRQ5
position 5 is connected to
position 4 is connected to IRQ3
position 3 is connected to
position 2 is connected to IRQ5
position 1 is connected to IRQ4
I'd guess printer IRQ position 7 or 8, serial port A position 1 2 & 3, serial port B position 4 5 6
JP4 Just a guess
1 & 2 printer port enable/disable/portselection
3 &4 serial A enable/disable/portselection
5&6 serial B enable/disable/portselection
should be easy enough to test, boot the computer with the card in it from floppy or harddisk,
and run checkit or msd or a similar program that shows you which ports are available and at what location and run through the JP4 jumper possibilities.
Testing the IRQs is another matter.
Do not ask Why !
