First post, by Lylat1an
I've read that some "high end" CF Cards support TRIM, but is there a way to know if mine do before installing?
Also I'm seeing two DOS TRIM programs online, is it better to use RLOEWE's utility or DOSFSTRIM?
Reply 1 of 2, by douglar
Install the Intel SSD Toolbox. Under View Drive Information look for Word 169, Bit 0 - Data Set Management Supported. If that bit is 1, Trim is supported.
CrystalDiskInfo might also be able to tell you.
I don't have any experience with DOS trim programs, so I can't help you out there.
Reply 2 of 2, by crusher
Look for R.Loews Trim.
It should include a TRIMCHK.EXE that checks for Trim support of the drive.
