First post, by zuldan
- Member
I've read these can be a pain to initially setup but I'm having no luck with it.
I've tried all sorts of BIOS settings (PnP OS off/on). Made sure the PCI slot is assigned IRQ 5 but I cannot get it to work. The motherboard I'm using is a GA-5aa rev 3.2. I also put the card in a PII board but have the same issue.
ESSCFG.ini is in C:\ and the drivers are in C:\SOLO1. Grabbed these files from Phils website.
Any hints to put me in the right direction would be greatly appreciated.
Does anyone know what these jumpers do on this particular Solo 1 card?
