385387386 wrote on 2024-05-01, 09:00:AMD 40MHz 80386DX Processor
IIT 40MHz FPU
386WB classical mainboard
32MB ram blaster low latency FPM ram
ATi VGA Wonder (Mach 8? […]
IIT 40MHz FPU
ATi VGA Wonder (Mach 8?)
I had issues with this mobo and some earlier stepping 386DX CPUs. The system would glitch of freeze when using coprocessor, sometimes as early as the BIOS detection code. Just FYI.
Not sure how much cache you have there, 64 KiB? On mobos with 128 KiB you'd probably get +0.1 FPS, and IIT is not exactly the fastest NPU out there. The later variant of Intel 387DX is faster, the Cyrix offerings are even better and for some reason the top spot - for Quake anyway - is ULSI MathCo 40. You can get a whooping 2.0 FPS with it. And that's with only 8 MiB of system RAM and a decent CF card to get low latency reads. But that's for the demo Quake, I suppose for full version or playing it (yes, it's a joke) your 32 MiB setup could prove superior. But do try 8 megs for the benchmark, it might just help cache performance.
EDIT: Oh and the VGA card matters less then NPU but it still does matter. I used Trident 8900D with 1 MiB of VRAM and jumpered to 0WS ISA.
