First post, by Exploit
Does anyone know if Zone 66 uses Virtual Control Program Interface (VCPI) or Unreal mode?
What I've already found out is that Zone 66 runs in protected mode and is incompatible with OS/2 and Windows, meaning it doesn't use a DPMI server.
Reply 1 of 2, by Grzyb
It's also incompatible with EMM386, right?
That would suggest it doesn't use VCPI.
Nie rzucim ziemi, skąd nasz root!
Reply 2 of 2, by Gmlb256
Zone 66 is notable for not letting you run it when a XMS driver is installed.
