First post, by dadocastro2801
I recently got an XT-CF lite 4.1 card (https://github.com/skiselev/xt-cf-lite-v4) for an Amstrad I have been trying to put an OS on for almost 4 years now... I guess I can't give up.
The card apparently works with the bios of the old owner.
The attachment Card BIOS.zip is no longer available
BIOS RAM address: CA00h
IDE controller base address: 300h
Boot driver: 80h
I have been trying to manually put ms-dos 3.2 on the CF but the amstrad can't boot from it either it doesn't detect a boot partition or it says it's the wrong disk. I can't really install it from a floppy because the floopy disk drive either can't read the disks or is malfunctioning, I was able to make it boot a system disk from ebay but it stopped working when I tried to put the drive back in its metal holding, I am also looking to buy another floppy just to check.
Any ideas?
Reply 1 of 2, by konc
I'm not sure I understand exactly the problem.
Is it creating a bootable CF on a different machine and then using on the Amstrad, or the XT-CF doesn't work with it? Or you don't know which of the two?
If it's the XT-CF and since you mentioned a previous owner, I'd start by making sure that the BIOS is configured for an XT.
Reply 2 of 2, by dadocastro2801
I don't really know much about the XTIDE universal BIOS but it seems to be configured for an XT and the ebay listing also says it is configured for an XT
