Native IPX support
First post, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Hello,
this one lets Dosbox talk to a real networked PC as well as other Dosboxes using IPX network.
Type
ipxnet startni
to activate that mode.
It is Windows only, but it should not be difficult to port it to any platform that uses BSD socket style. This includes my previos Netbios patch, but I got rid of the localloopback thing (NOT fixd the warcraft1 bug, it's just hidden)
Also included is a small utility "setipx" which lets you set the IPX node address on a DOS computer - might be needed to play C&C.
Netbios will not work in native IPX since the host computer already uses the Netbios port. But there is a chance "native netbios" can be implemented.
Edit: For latest progress always see the end of the thread!
Reply 1 of 14, by wd
Rank DOSBox Author
DOSBox Author
Interesting thing, now....
> (NOT fixed the warcraft1 bug, it's just hidden)
Could it be that it was hidden the same way under a real
network? Then the implementation would be correct.
Have to dig through your sources 😉
Reply 2 of 14, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Nope, can't be. The local loopback is curently only given to programs that need it, which are netbios.exe and C&C. Netbios is detected by port number and C&C by the all-networks-broadcast (like in CVS).
Reply 3 of 14, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Make Warcraft1 work, source only.
Reply 4 of 14, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Fix Quake.
Edit: also includes Warcraft1 fix.
Reply 5 of 14, by HunterZ
hal, are those two patches incremental, or does one supercede the other?
Reply 6 of 14, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Each of these diff files is a complete patch for CVS.
Reply 7 of 14, by Onsympatico
Ok, some basic questions,
How do I apply this .diff patch, or is it already done in the latest cvs build?
Has anyone got c&c multiplayer going yet? I tried all sort of things but under cvs it won't even show me the host/join screen.
Is there a way to configure the internal network number?
That setipx thingy always sets the same number no matter what I type, and isn't that the MAC adress?
Again,thx for your excellent help so far
Reply 8 of 14, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
This is done with CVS programming tools. It's not in the latest CVS but in the binary I provided.
In dosbox command line type 'ipx'. If it prints false, type 'ipx true' to enable IPX at all. I have successfully played C&C even across dosbox - real dos computer.
The setipx utility is supposed to set the Network number on a real dos machine. It doesn't work in dosbox. For C&C (no other game I know of) this is required since it uses some strange packets. Both computers (Windows and dos) must have the same Network number, and since there is no easy way to set that on a dos client without a server I made this utility.
Reply 9 of 14, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Update:
- implement IPX function 0x1a - get driver packet size.
Fixes Death Rally.
Reply 10 of 14, by Darklord42
Is this patch still necessary with the .72 build? I am trying to get armada to work online in .72 as HCl's patch uses the old .65 build. I know HCL said that Armada blocked IPX packets from your NetBios patch. Is this still relevant?
Reply 11 of 14, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
With 0.72 just load netbios.exe before starting Armada.
1+1=10
Reply 12 of 14, by Darklord42
Thats it? what about armada blocked netbios.exe's ability to receive IPX packages? Is that still a problem?
Reply 13 of 14, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
iirc the issue was missing IPX functionality. Armada works fine for me using 0.72 and netbios.exe, at least on LAN.
1+1=10
Reply 14 of 14, by Darklord42
Thanks a lot!
