First post, by Ahrle
Picked up a bloated Presario 700 (Athlon 4, 1.20 GHz) that I want to make factory fresh. It has a secondary partition labelled SYSTEM_SAV, to extract files from.
How do I do this? There are several folders of uncertain DOS programs and about 25 files in parts of 48MB. and some text documents hint CDs should or must be inserted.
All help appreciated! Thanks
Project 357575: ECS UC4914-G | i486DX2-66 | ET4000/W32 | CT3900
Main: IBM PC300PL | PIII 750 | Viper AGP + V2 SLi | CT4500
Reply 1 of 5, by Repo Man11
Those sort of systems didn't usually ship with actual install media (like a Win98 CD) but instead had a recovery partition on the hard drive that could be accessed by using a "Recovery CD" included with the manual(s). It would be much simpler to format the drive and install whatever OS you choose (even better, replace the painfully slow stock hard drive then install the OS of choice). If you really want to have it use the Compac version, you can likely find a recovery CD image with some searching.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 2 of 5, by Ahrle
Repo Man11 wrote on 2024-05-12, 17:53:
Ok, yep the recovery CD is what I'm looking for. It's not a fast system anyway 😜
Reply 3 of 5, by elszgensa
25 * 48MB = 1.2GB sounds about right for an XP system image plus preinstalled bloatware... I'd make an effort to hunt down the correct restore disc, it'll know what to do. Or maybe that's even a bootable partition? You don't have "show file extensions" enabled, so it's probably the same for showing hidden/system files meaning we don't know what else might be hiding on there. Does it show up in the BIOS's boot device selection?
edit: This guide suggests F10 at boot, which is similar to what I had in mind. It also has a link to some version of their recovery software.
Reply 4 of 5, by Repo Man11
Using this search term "Presario 700 recovery disk" I got a hit for "Compaq Presario C700 C751NR Recovery Discs" at The Internet Archive. I won't link to it because of possible copyright issues, but I think that's what you're looking for.
Reply 5 of 5, by Ahrle
elszgensa wrote on 2024-05-12, 18:16:
Yep, I've entered BIOS but couldn't find an option for recovery boot. Sure one of the most limited BIOS'es I've seen. User manual suggests CD to launch system recovery.
Repo Man11 wrote on 2024-05-12, 19:40:
Appreciate your effort, but C700 is a Core 2 Duo system... meanwhile 700 is a half-decade older Athlon 4. The exact model number is Presario 733EA.
Edit: Just as I posted this and had a closer look on internet archive I found it. Sweet!
Thanks for help!
