First post, by demiurge
Does anyone use a ramdrive on their retro machines (386-686 class PCs DOS or OS/2)?
What are they used for? I know that the winME system help disk uses one to load the tools on, is this just to speed the tools up and not load off the floppy disk?
Does COMMAND.COM ever get called after boot that might get an improved speed being referenced from the ramdisk?
Does OS/2 have a pagefile that could use a ramdrive to improve speed? I'm thinking about playing with OS/2.
Reply 1 of 6, by Cyberdyne
ME boot floppy just expands compressed files from floppy to ramdrive. It is for space constraints.
Large memory floppy only machines may use it. Maybe compiling programs. But in reality in a ordinary work and ordinary 386/486 with ordinary hard drive, you do not really need it.
Reply 2 of 6, by fosterwj03
Back when I used a 486 or Pentium every day, I made a small RAM drive to hold my browser cache. I had autoexec.bat make the cache folder during boot up. It was much faster than a hard drive, and I didn't care if it got erased at power down.
Reply 3 of 6, by Grzyb
demiurge wrote on 2024-05-12, 20:40:
Yes, it often happens that COMMAND.COM gets reloaded, eg. Norton Commander reloads it whenever running a program.
Copying COMMAND.COM to the RAMdrive, and doing eg.:
SET COMSPEC=D:\COMMAND.COM
may indeed speed things up a little.
But I've never found it worth bothering...
If you have so much memory that you will never need swap, you can try changing:
MEMMAN=SWAP
to:
MEMMAN=NOSWAP
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 4 of 6, by Cyberdyne
fosterwj03 wrote on 2024-05-12, 22:24:
Noice ... a fast incognito mode for fast porn viewing pleasure. 😂
Reply 5 of 6, by analog_programmer
Back in the 80386/80486 days my home computer had only 4MB of RAM (the RAM modules pretty expensive back then), so other than a one-time test, I've never used DOS RAM-drives. Later hard drives got bigger and fast enough (and win 95 came) that I forgot that there was such a DOS tool.
Nowadays old FP or EDO RAM sticks are (relatively) cheap, so RAM-drive is good option for fast "temp drive" on retro DOS computer - for example 386SX machine maxed-out with 16 MB of RAM. I think FreeDOS uses RAM-drive by default.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 6 of 6, by Cyberdyne
analog_programmer wrote on 2024-05-13, 05:14:
Yo are right in that point, that all my 486 and P5 computers get unnaturrally high ammount of RAM. 486 at 64MB. Nobody had that ammount of ram in their home 486. And only few P5 motherboards stay at 64MB and only because Cacheing in some motherboard is limited to that.
