Stonekeep DOSBOX sound
First post, by tanz
OK. I got SK running. In setup the sound and music run perfectly. But when it runs in the game, the sound is bad. I've changed rates and frameskip to different numbers, but to no avail. It is skippy and when characters talk you can't understand what they say at all. Any ideas to edit it to make it run properly? Should I try VDMSound? Can it even work with DOSbox? I've looked at some of these posts and people say they get the sound running fine in DosBox.
Thanks in advance.
-tanz
