First post, by Windows9566
my Satellite 410CDT i just got off ebay earlier just died out of the blue on me, when i went to turn it on, i get the Toshiba Video BIOS and then it hangs on a blinking cursor, i tried reseating the ram, removing the HDD, changing the HDD, etc. nothing changed, IDK what to do now.
R5 7600X, 32 GB RAM, RTX 3060 TI, Win11
P3 750, 384 MB RAM, Matrox G400, Sound Blaster 32, Win98
PMMX 166, 64 MB RAM, S3 Virge DX, Aztech AZT2316R, Win95
486DX2 66, 32 MB RAM, Cirrus Logic GD5430, Aztech AZT2316, DOS
Reply 1 of 2, by Thermalwrong
Take it apart and re-seat the sound-card board that connects the HDD. When you reconnect it make very sure that the white cable with something like 6-wires is connected securely at both ends because that powers the hard drive on that model.
That happened to me a while ago.
Hopefully that's all it is?
While you're in there it's a good idea to check for corrosion and remove the standby battery under the keyboard and throw it in the bin. The smaller RTC battery is probably also leaking and should be replaced.
Reply 2 of 2, by Windows9566
no corrosion except on the connectors for each batteries, i tried and checked everything and no change. i already chucked both dead batteries in the trash
