First post, by Bakersor
Hi guys,
Found this motherboard in the wild and sadly the battery leaked. I removed the PLCC CPU socket because the contacts were corroded and broken; ordered a new one. I used vinegar to neutralize the battery juice.
Traces in the area have a brownish color. Do i need to remove the remaining components and clean the solder mask, tin the traces? Or does it look good to you?
Sorry for my low quality photo and thank you in advance.
