First post, by Achilles2
Dear All,
Looking for some advice on which of these cards should I pair with my P200 MMX (I have both sitting around). Thank you!
Dear All,
The Lightspeed will probably perform better with DOS and Windows 2D games, but the Nitro supports some hardware 3D acceleration, although with a P200MMX you may be better off just using software rendering.
Thanks devius. I'm planning to use it mostly for DOS gaming, so guess the Lightspeed is the way to go.
Either one should be fine for DOS.
In DOS games, ET6000 has the ultimate speed, but considering the compatibility of DOS games and the acceleration of Windows GUI, I think STB Nitro 3D/GX 4MB is a better choice.
Pentium MMX233, Zida TX98-3D, 64MB, Riva 128, Aztech Waverider Pro 32-3D, HardMPU-wt
K6-III+550, FIC VA-503+, 256MB, Voodoo3 2000, Creative AWE32, HardMPU-wt
Tualatin-1.4G, QDI A10BM, 512MB, G400, Voodoo2 SLI, Creative AWE64
Are you sure that STB Lightspeed 128 has 2.25 MB?
I only saw it with 2 MB - and that means no 1024 x 768 x 24bpp mode.
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Grzyb wrote on 2024-05-28, 22:55:Are you sure that STB Lightspeed 128 has 2.25 MB?
Yes, it's the one detailed here:
https://dosdays.co.uk/topics/Manufacturers/st … stems.php#LS128
Achilles2 wrote on 2024-06-17, 18:26:Yes, it's the one detailed here:
It doesn't list 1024 x 768 x 16.7M modes...
But OK, I've found this page - https://wiki.preterhuman.net/STB_Lightspeed_128
There are photos of two variants:
2 x MD908 = 2 MB
2 x MD909 = 2.25 MB
