First post, by Trashbytes
- Oldbie
Hi have a bit of an issue trying to identify if a broken pin on this CPU is a required pin a spare voltage pin or not connected, I have the pin maps but with limited experience in deciphering these pin out maps I'm hoping someone here more knowledgeable can lend a hand. Its either a VLDT pin or a Memory channel pin ...assuming Im at least on the right path with reading this map.
I haven't thrown this CPU in a board yet as I dont want to cause it any further damage as these 3700s are rather hard to get hold of, If its a required pin then Im going to go microscope hunting so I can try repairing it .. or I will do a socket mod with a bit of stiff wire.
Apologies about the pics, did my best with the limited macro camera I have.
