First post, by theshinyknight
I have installed XP 32 SP3 on a couple of old HP computers, and so far they are not too shabby; getting about 5K on 3dMark 05 and 10K on 3dMark03; using the integrated GPU on the A8 APU (R7 series Radeon) . Not bad at all for salvaged computers from a bin!
Now I would like to see if I can improve things; I got the latest drivers supported by the manufacturer for this APU, which is 9.0.300.3001 (1/4/2014); is there anything newer or better to improve performances or do I have the best I can run on XP 32?
Also I have a Compaq Pro 6305 Small Form Factor, which has a couple of slots for cards (I think one PCI and one PCI-Ex16 (3.0), so I can put in there either card type. Although the case is very small so won't fit large cards and the max power supplied to the slot is 10W. What would be a good card for 2003-2005 type of games ? Planning to go for 1024x768 resolution, or 720p at most. Thanks!
