First post, by analog_programmer
- Oldbie
I have one version of these Soyo SY-5TC motheroards: https://theretroweb.com/motherboards/s/soyo-sy-5tc . It is with Intel 430FX (Triton I) chipset and thus it lacks any support for SDRAM. When I try to boot the mobo with Pentium P54C 100 MHz (3.3 V) and two Fast Page Mode RAM 72-pin SIMM 16 MB sticks it starts, hangs at "C6, C1" POST codes and then it starts "beeping" repeating one long "beep".
According to this long BIOS "beep code" and "C6" POST code there's some problem with RAM, but the FP-RAM installed is perfectly fine and working on different socket 7, socket 5 or 486 (socket 3) boards. The manual states, that this motherboard supports only EDO-RAM 72-pin modules, but according to TRW site it also supports FP-RAM:
I don't have any 72-pin EDO-RAM sticks and I don't know for sure if the Fast Page Mode type SIMMs are preventing the mobo from normal booting, because i430FX chipset supports both FP-RAM and EDO-RAM.
The AMI (my mistake) Award BIOS on the board is very early version, if this matters. I can flash newer version with EEPROM programmer, but I don't know which of the BIOS dump files on TRW site will be suitable. According to one semi-torn label the board version seems to be version ending with "U".
Can anyone here confirm that this Soyo SY-5TC board only works with EDO-RAM sticks?
P.S. I've tested the board with and without any cache SRAM chips installed (known to be good and properly set by jumpers when installed) and the result is one and the same - hangs at "C6, C1" POST codes repeating one long "beep".
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
