First post, by andrea
andrea
Offline
Hello,
anyone with a GF5200 Ultra can please post a vbios dump?
I'm currently working on a 5200 on which i put 256MB of Samsung TCCC ram, voltage is 2.78V (with TCCC is usually not worth going much higher) running on MSI FX5500 (same reference pcb) bios (i've noticed earlier 5200 bios create weird artifacts if fitted with 256MB ram).
This frankenstein card is currently working perfectly stable with no artifacts at 248MHz ram (496 DDR). At 250 it crashes hard, with a hard freeze and chequermack artifacts all over the screen, not the usual ram slighly over the limit stripes/dots.
I think it's very likely that the 5200Ultra, with its higher ram frequency, must have looser timings so working with those maybe i can reach 500Mhz.
Thank you,
