First post, by zzzxtreme
hi guys. I'm trying to setup tcp on multiuser dos (version 5.1) on PC
os installed successfully. my wyse terminal is also able to connect to the pc via serial
loading packet driver success (3com 0x60)
but when trying any mtcp command like dhcp or ping it just fails
using another hard disk with ms-dos on the same pc , packet driver + dhcp success
any help is highly appreciated!
Reply 1 of 2, by mbbrutman
Maybe send a trace to the mTCP support staff? ;-0
Reply 2 of 2, by zzzxtreme
thanks for the response. also can't thank you enough for the work you do.
I'm able to solve the problem by just changing to an older version of etherlink
works great with multiuser dos
