First post, by PlaneVuki
Hello.
Benchmarks are usually done with sound off, but we play games with sound on.
I have two pci sound cards to use on socket370 motherboard with win98se.
On a mobo ms7127c and mendocino 433 and mx400 agp, quake3 640x480x16bit:
Without sound I am getting 50 fps
With cmi8738 sound I am getting 37 fps
With ess solo1 sound I am getting 46 fps
For both sound cards I am using drivers from philscomputerlab website.
https://www.philscomputerlab.com/c-media-cmi8738.html
The question is:
Why cmi8738 is so slow compared to solo1 ? (I have two cards with this chip, same result)
And how to make it work fast (or more efficient), like solo1?
Perhaps someone knows a better driver?
Have you ever checked fps drop with cmi8738, compared to no sound?
I don't want any fancy stuff from a sound card, 3d sound, EAX, gameport, microphone, etc..
Just want normal stereo sound that doesn't cause a lot of fps drop.
Thanks in advance.
Reply 2 of 4, by PlaneVuki
Thanks theelf.
With this driver I get 42 fps. Still worse than solo1, but at least better than phils driver.
If someone knows even better driver I would be glad.
But this will do for now.
Reply 3 of 4, by theelf
PlaneVuki wrote on 2024-06-03, 20:59:
Thanks theelf. […]
Thanks theelf.
Never had much luck with cmi8738 in win9x, random problems, etc, but they work much better in NT, there is even some open source drivers, but 2000+ https://code.google.com/archive/p/cmediadrivers/
Reply 4 of 4, by kingcake
As pointed out above, WDM drivers will almost always give worse performance. There are lots of variables. The CMI might be using a virtual software based MIDI device while the ESS has hardware FM synth, etc, etc.
Or just plain old poorly optimized drivers. Not uncommon with budget parts.
