First post, by popcalent
Hi, all.
I have a 386 DX-40 running MSDOS. I'm using an ES1868 sound card that was working great until it stopped working. This is the card:
The attachment IMG_20240602_132311.jpg is no longer available
I turned on the computer today and ran a game that has music through the sound card, but the music was on the PC speaker instead. It didn't let me select adlib music, so I restarted the computer. Then it worked fine. But the next time I restarted the computer, I had the same problem. Then I realized this was showing up on boot up (ignore the mouse error, it's fine):
The attachment IMG_20240603_183047.jpg is no longer available
I haven't changed anything on my autoexec.bat or config.sys:
The attachment IMG_20240603_183111.jpg is no longer available
The attachment IMG_20240603_183132.jpg is no longer available
And the paths are correct:
The attachment IMG_20240603_183156.jpg is no longer available
I made sure the sound card itself wasn't lose, but still it doesn't work. What could the problem be?
Reply 1 of 2, by quigonhu
If you're sure this sound card is still functional
1. Try to reset the BIOS
2. Try to use another ISA slot
If nothing changed, get a multimeter, try to measure the following voltages, +5V, -5V, +12V and -12V. Make sure these voltages are available.
Reply 2 of 2, by Grzyb
It looks like a hardware problem.
Try the card in another computer, and try another card in this computer...
Nie rzucim ziemi, skąd nasz root!
