First post, by johnyept
I have a MSI RX9250 T128 (Radeon 9250 128MB) that I converted into an ArcadeVGA card, to serve as a backup to my original ArcadeVGA 9250 card. In the process, I forgot to backup the original firmware, so I'm trying to find it just in case I decide to restore the MSI card back to normal.
To backup the firmware, all it's needed is a boot floppy or Flash Drive with FreeDOS, Flashrom 2.23, and the following command: flashrom -s 0 backup.bin
RETRO-W98/2K: MSI MS-6309 v1.0, P3 1Ghz, 3x256MB, GF5600 128MB AGP, VD2 PCI, RTL8139D PCI, TB400-2541 PCI, ESS1868F ISA, 160GB IDE
RETRO-WXP/7: ASUS P5KPL-AM EPU, XEON E5450 3Ghz, 2x2GB, GTS 450 1GB PCI-E, 120GB SSD, 1TB sATA
Reply 1 of 1, by BleedCap
My version is a bit different, Model 8999 Ver 1.A.
The attachment 14-127-148-08.jpg is no longer available
The attachment ATI_Radeon_9250_128M_(MSI).gif is no longer available
In case someone need/search for this in the future.
I use RaBiT-2.2.0 to save the firmware/bios.
The attachment MSI_RX9250_T128.zip is no longer available
