First post, by BitWrangler
- l33t++
Hi folks,
I didn't seem to run many PCI soundcards "in era" as it were. Mostly had boards with "adequate" sound on board and didn't get all audiophiley about it. In fact, I don't even have many boards now that are purely PCI and don't have some audio capability. So I don't seem to have much "feel" for where various PCI soundcards belong.
What I know I've got, seen in last few months:
Turtle Beach Riviera CMI8738
Unknown CMI8738
ALS4000
ESS1370
AWE64 PCI CT4380 ?
SB128 PCI CT4810 ?
SB0410
SB0090
Live CT4780 x3
What I might have around "somewhere" only vague memories of them, or they might be hiding in a system or something: SB64 Value?? ES1968 Maestro-2, Another CMI8738, Another ALS4000, possible 2 or 3 more randoms hiding.
Basically then, I am unaware of their special niche talents, apart from the more obvious like the SB0090 is the only one with EAX right, so need that for mid XP stuff.
I am also not real up to date with which ones have been redeemed by better DOS setting programs or SBEMU using them for better SB compatibility. i.e. they used to be a PITA but now they are not.
So it seems unlikely that I'll be using them with CPUs that are slower than 500Mhz native, but may have some tuneable socket A mobile, or use throttle on P3/P4.
OS range, Late DOS, maybe some Glide DOS stuff, through win9x to XP.... not sure if I'm gonna need one or two that can get drivers for Vista or Win7 64bit.
Ideally, I'd like to identify the best for wide use, DOS thru XP and the ones that are best at directsound, for DX gaming.
Only vaguely got the builds in my head at the moment. For mid XP that might use the EAX at the moment, out of what I've got I'm thinking PentiumD with a GF7800GS and the SB0090 or something like that, might have some 98/XP stuff that's around 1.5ghz in socket A, XP only socket A thoroughbred on NForce2, and that kind of thing.
One of them might be wanted in a high speed K6-3+ setup along with an ISA card, in that instance might be looking for the low CPU load some are best at.
Anyhoo, if anyone can help me calibrate my gut about what most belongs where that would be great.
