First post, by habys
Impulse Tracker sounds garbled -- playable but tempo is too slow and the sound is corrupted. A work around is to set the output to mono within Impulse Tracker. I don't have an issue with Scream Tracker, Open Cubic Player, or any games. Anyone experienced this or anything like it?
I've really only tried removing various parts of my startup to make sure they aren't causing troubles, but to no avail.
Thanks for any suggestions.
system
PII 450MHz
Video: Number Nine Imagine 128
IDE: XT-IDE v1.1.5
PSU: Seasonic Snow Silent AT
Extended Memory: 393216K
OS: MS-DOS 6.22
autoexec.bat
@ECHO OFF
CTTY NUL
C:\CMD\EMM386.EXE AUTO
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
SET MIDI=SYNTH:1 MAP:E MODE:0
SET CTCM=C:\CTCM
SET TEMP=C:\TMP
SET TMP=C:\TMP
SET COPYCMD=/Y
SET MTCPCFG=C:\MTCP.CFG
C:\SB16\DIAGNOSE /S
C:\SB16\AWEUTIL /S
C:\SB16\MIXERSET /P /Q
C:\CTCM\CTCU /S
LH C:\SDD\UNIVBE.EXE
LH C:\CMD\CTMOUSE.EXE /P /B
LH /L:0;2,45456 /S C:\DOS\SMARTDRV.EXE /X
LH C:\DOS\SMARTDRV.EXE 8192 16 A+ B- C+ D+ E+ F+ /N /E:32768
LH C:\CMD\ZENO\ZENO174.EXE /Q
LH C:\CMD\DOSKEY
PROMPT $p$g
PATH C:\VIM73;C:\DOS;C:\CMD;C:\EXT
LH APPEND C:\EXT
MODE CON: RATE=32 DELAY=1
CTTY CON
config.sys
SWITCHES=/F
DEVICE=C:\CTCM\CTCM.EXE
DEVICE=C:\DOS\HIMEM.SYS /NUMHANDLES=128 /TESTMEM:OFF /Q
DEVICE=C:\CMD\EMM386.EXE X=B800-C7FF I=B000-B7FF RAM A=64 H=128 D=256 AUTO NOTR
DEVICE=C:\CMD\DOSMAX\DOSMAX.EXE N+ P- R- U02 U08 U09 U0A U0B U0C U0D U0E U70 U72 U73 U74 U76 U77
DOS=HIGH,UMB
BUFFERS=11,0
LASTDRIVE=H
FCBS=1,0
STACKS=0,0
DEVICEHIGH /L:1,12048 =C:\DOS\SETVER.EXE
DEVICEHIGH /L:1 C:\CMD\NANSI.SYS /X
FILES=40
