First post, by Lostdotfish
I'm tinkering with a Gigabyte GA-6VXE7+ (Apollo 133 Pro) system. It's a Windows 98 system.
I added a Sil3114 PCI card and flashed it with the non-raid BIOS.
I booted into GParted via the Ultimate Boot CD and could see my SSD attached to the PCI card. I set the partition (127GB) and then cloned my IDE W98 install over to it .
In the BIOS I have set boot order to SCSI, A, C but I cannot get it to boot from the SATA drive.
I thought maybe I'd messed up the cloning process, so tried to do a fresh install from CD. Upon booting the CD it does not see the SATA drive.
If I boot into my IDE Windows 98 install, it doesn't see the SATA drive.
Boot back into GParted and I can see it fine. I can browse the cloned folder structure and files just fine.
Any ideas what I'm missing in order to get this system to boot from the SATA drive?
