First post, by PolygonYT
Hi. I’m new to this site. I am building a Windows 95 setup. For some reason I cannot install the CD Drivers.
Here’s the command I entered:
MSCDEX /D:MSCD001 /l:d
Here’s the output
Device driver not found: “whatever I input
No valid cdrom device drivers selected
Do I need proprietary drivers? Someone, help me!
Reply 1 of 8, by wierd_w
You need more than just mscdex.
You need a suitable cdrom device driver that mscdex can interface with.
LiteOn was predominantly ide/atapi, so try vide.sys, atapicd.sys, oakcdrom.sys, and pals. (You only need one, but try to find the smallest one that works with your drive and controller)
Eg, from the win98 ebd:
[Config.sys]
devicehigh=A:\oakcdrom.sys /d:mscdoo1
[Autoexec.bat]
LH A:\mscdex.exe /d:mscd001
The 'mscd001' can literally be anything, as long as it matches between the driver loading, and the cdrom extensions being loaded.
Reply 2 of 8, by PolygonYT
THANK YOU SOO MUCH! I used oakcdrom.sys and it worked flawlessly. Anyways, Duke Nukem, here I come!
Reply 3 of 8, by PolygonYT
Wait, nope. When I type ANYTHING on D: it says:
Fail on INT 24
Reply 4 of 8, by PD2JK
Try another *.sys (driver) and make sure the drive is working at all. Put it in another system for testing.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 5 of 8, by PolygonYT
Error still occurs with ATAPI.SYS...
Reply 6 of 8, by Horun
Here is Liteon's DOS cd driver v4.0 from the archives.....try it. if still an issue read the manual...
Reply 7 of 8, by wierd_w
I second ensuring the drive actually works.
I do not know if your liteon suffers, but many optical drives have a belt driven spindle, and or, get a stretched/worn tray eject mechanism belt.
This either causes the disc to not spin, spin the wong speed, or fail to register the tray has fully inserted.
Other possible failure modes include dead laser pods, silly behavior on bus mastering controllers (or when paired with large lba mode disk drives), being all alone on an ide channel, and a host of others.
Go through the exhaustive checklist to ensure the drive is known good and working.
Reply 8 of 8, by PolygonYT
Horun wrote on 2024-06-15, 16:22:
I tried to install the drivers, but an error pops up.
