First post, by n0vac_
Hello people at VOGONS! Someone in a community told me to ask here and see if i can fix a computer i have.
The specifications are as follows:
The "so called" model of this computer according to the case: "Expert Digital Navigator" (it appears the motherboard has been replaced, and every component in here (maybe not the power supply?))
CPU: Intel Pentium E5700 (i think? that is what i remember from when i repasted it and when it booted up two times, i remember the BIOS saying it was clocked at 3GHZ)
GPU: None at the moment (everytime I plugged a gpu in while the computer was working, it didnt boot.), however i have a NVIDIA GeForce 8400 GS, and a NVIDIA GeForce 7300 GS from Gigabyte, although some of the pins on it have a bit of green. The GPU that was in here when we got it was the NVIDIA GeForce 8400 GS
Motherboard: MSi G41M-P26
RAM:1x1GB KINGMAX DDR3-1333 (might not be working?), 1x2GB ELPIDA DDR3-1333
Power supply: ALINE PX-450, 450W
HDD: Western Digital 500GB WD5000AAKS
DVD Drive: Some weird LG one, idunno.
We found this computer in our garage, and we thought to get it out and trying to fix it (it has been in there for 4 years, and that garage isnt very well insulated so its been through the cold, the heat, maybe possible rain etc...
Once we opened it up, it was pretty dusty so we cleaned it.
We found a VGA cable and a power cable (and a GPU) in a box so we took those and hooked up the computer to my monitor (a Panasonic TV from around 2009), pressed the power button and.. it didn't work!
There was no POST/BIOS beep, and no VGA output! However, there were lights on the front of the case, the fans were spinning, the led on the DVD drive was blinking.
The USB ports werent powering devices right however. For example, my main mouse (Razer Viper Mini) didnt have the leds on it powered up and only the sensor was alive. A cheap chinese mouse from a keyboard+mouse+headphone kit did work, leds powered up, sensor was on. The keyboard from that kit (also my main keyboard) did not have the leds on it turn on.
We removed the CMOS battery for about 2-ish minutes and then put it back. Didn't boot.
Reseated the ram. Didn't work.
Unplugged the GPU and HDD and... it booted!
Turned it off, plugged the HDD in, and it still booted!
This time, it made a POST/BIOS beep, it had VGA output, and USB was working (the keyboard had the leds turn on, and it worked to let me access the bios and the install of Windows 7 Ultimate on it, my main mouse worked).
We explored the files on it a bit, and we saw it had some games installed. I thought "Let's open this Geometry Dash version from 2017 (I'd assume 2.1)". We double clicked the icon and... the computer froze! Screen looked a bit weird too, it was like there were 2 images of our desktop interlaced.
So we turned it off from the button. I thought "Lets try the GPUs". Didn't boot after. Tried everything and nothing. Went under my desk.
All of that happened yesterday (6/15/2024).
I woke up today, and thought "Let's try to fix the PC".
Took it apart, and after trying the same steps as yesterday, it didn't work.
But then, I removed the 1GB RAM stick, and it booted!
We explored the files on it again and then thought "Well, if that ram stick was faulty, maybe the GPU's weren't, so lets try them again!"
Was NOT a good idea. Didn't boot after.
We took apart the whole computer, removed the fan and heatsink (Stock intel cooler), and under it was an unholy abomination of dust mixed with thermal paste. We cleaned that up and replaced the thermal paste with some thermal grizzly kryonaut i had laying around.
Hooked up the fan again and... still didn't boot!
So far, I've reseated every connector (from the powersupply, the front case connectors, everything), tried every orientation i could of putting the 2 sticks (or only one stick) of RAM at a time, removed every connector except what i thought was necessary (20+4 pin motherboard connector, 4 pin cpu connector, fan connector, the vga cable and power cable) and it's still stuck in that state of limbo where theres no POST/BIOS beep and no VGA output, but theres power! The CPU works, as after that, I removed the fan and turned it on, and it got hot, so i assume its working. Whats the issue? How can i fix it?
Not sure if this is the right or wrong topic to post in either... so sorry if its not the right one!
Reply 1 of 15, by dominusprog
Use a contact cleaner on both the RAM and PCIE slots. Also try a different power supply.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 15, by n0vac_
dominusprog wrote on 2024-06-16, 18:15:
Best i can currently do is use 30% isopropyl alcohol, sadly. However i see people saying 99% IPA is a decent alternative to contact cleaner when doing similar stuff and the only difference between 30% and 99% is the fact that 30% has more water so it takes longer to dry, but im fine with that longer wait time
+ i think its fine as theres no electric current going through it.
Reply 3 of 15, by dominusprog
n0vac_ wrote on 2024-06-16, 19:08:
Well, you can wash the whole motherboard with hot water and soap. One other thing, it's better to disconnect those USB wires, they didn't use a standard wire with shielding.
Reply 4 of 15, by n0vac_
dominusprog wrote on 2024-06-16, 19:15:
what would be so bad if they stay connected? this is my first experience with taking apart a proper computer (and not a laptop) so im pretty confused with everything (and also why so much stuff needs so much pressure (the ram going in, cables going out etc)
Reply 5 of 15, by Horun
Check the coin battery voltage, if not at least 3.0v it needs be replaced. Some boards will not boot proper if that battery is low or dead.
Reply 6 of 15, by n0vac_
Horun wrote on 2024-06-16, 19:46:
uuf, i have a small issue:
i dont have a multimeter (very sad, but planning to get one soon, along with a heatgun)
dont think theres another way for me to check it unless the weird arduino clone i have works to somehow do that (if it works as a simple uart thing to let me access other devices uart interface with my laptop and it also apparently works according to others as a bios flasher so 😜 maybe it could)
i dont actually have a lot to work with here but ill see if i can check somehow or if any neighbours or friends (or family) have one
Reply 7 of 15, by n0vac_
After cleaning the slots and the components with the 30% IPA, and letting them dry until now (about 14-16 hours?), i've reassembled the computer, plugged everything in, and its still stuck in that weird limbo state of not having a bios beep but power flowing through.
Wild guess but; couldn't the BIOS on the motherboard somehow be screwed or something?
I mean, the builtin pc speaker does 3 long beeps when theres no ram, but when you put ram in, theres 0 beep, no booting, no vga.
Reply 8 of 15, by n0vac_
n0vac_ wrote on 2024-06-17, 11:31:
And if the BIOS is screwed, couldn't i somehow flash it? Although im not too sure what could be the bios chip on here in the first place, or how to flash it considering i dont have any soldering tools or programmers (but i do have an arduino and ive heard they work as programmers sometimes)
Reply 9 of 15, by n0vac_
Uhoh, those dots on the traces of the motherboard that dont look like metal on it dont seem good.
Reply 10 of 15, by n0vac_
Nevermind, brother blew up the power supply when trying to fix the pc with me (Changed the switch on it from 230v to 115v when it was plugged it, my room was half full of smoke)
Also says he wont buy a new one so, oh well
Reply 11 of 15, by gerry
n0vac_ wrote on 2024-06-18, 10:09:
ouch! well, it might have been the power supply but then that pic of the mainboard doesn't look too good either, though ive seen worse still working, it could even be a single failed capacitor somewhere
its worth buying a multimeter anyway, just one to keep handy. even a very cheap on is always a good addition for checking low voltage things.
i think if it were me i would consider keeping the case, freeing the cpu & cooler and ram, looking online for a very cheap similar motherboard in working order (either empty or with cpu/ram as bundle), buying a new power supply (cheap ones are often ok-ish if you don't want to spend big, but well regarded brands and models are better). Maybe a cheap SSD. Making sure all components are compatible of course.
then you may end up with a 775 system, e5700 cpu, 2gb ram, 120gb ssd + 500gb hdd, gs8400 card, dvd rom, onboard sound and all ready for win 7 and some older games circa 2000-2007ish
in any case, you had yourself a true retro adventure with it all 😀
Reply 12 of 15, by n0vac_
gerry wrote on 2024-06-18, 10:43:
ouch! well, it might have been the power supply but then that pic of the mainboard doesn't look too good either, though ive see […]
i mean, i might have accidentally also screwed the mainboard while screwing it in and unscrewing it so : P
but yeah once i can convince someone in my family to buy a multimeter i will
ive decided to currently throw the case back in the garage but take all components that i can out of it (dvd drive, mainboard, fan etc), its either i convince them to buy a power supply and a motherboard for about the price of a slightly more modern refurbished pc or i find a cool old pc that works thats cheap
untill then, we will see what happens. i could ask my father if hes fine with me taking an old laptop (not that old, some toshiba that ran windows 7 i think) out of the attic, but he will probably say no
we also apparently had another, older pc but it might have been sold to someone because of my grandma (even though it wasnt hers, or anything in there wasnt hers, but whatever)
Reply 13 of 15, by momaka
If I had to guess, probably either the power supply or that stock Intel "push-pin" style cooler were the cause of all your system's instability.
The PSU is prime suspect, though. The included power supplies in Delux cases (or any cheapo cases for that matter) are pretty garbage. And even if that power supply was replaced, I can still tell you it's a cheap POS. How I know? - The sticker on it lists multiple models with different power ratings. This is something that ultra-cheap PSU manufacturer's do so they don't have to print different labels for their "different" model PSUs. So any PSU with multi-model list on its sticker should automatically be considered garbage.
But it looks like you / your brother already "took care of it" by playing with the voltage selector switch 😉 - good riddance!
Only thing such cheap PSUs are good for is to learn how to (de)solder parts, if you have any interest in that. In fact, cheap PSUs are the best when it comes to soldering practice, as they use single-layer boards and are easy to take apart. The components you gather from them can also be valuable if you ever intent to get into electronics repair or other electronic projects.
Anyways... aside from the crappy PSU, you may also want to remedy that stock Intel CPU cooler by either replacing it entirely (for something better) or at the very least get rid of the push-pins and replace them with bolts (and springs), backing against a backplate of some sort on the rear of the motherboard. I just did that last week to a similar ASUS socket 775 board that was acting up and not always booting reliably and not always detecting the RAM in all of the RAM slots. I got rid of the silly Intel push-pin cooler and like magic, all of the problems on that board went away.
Reply 14 of 15, by n0vac_
momaka wrote on 2024-06-21, 00:54:
If I had to guess, probably either the power supply or that stock Intel "push-pin" style cooler were the cause of all your syste […]
Well, currently, ive got some money, but ive decided that a good power supply and a new cpu cooler would be pretty expensive, but i ended up just buying a ThinkCentre off of a site for pretty cheap. Whenever i get more money, ill end up fixing the delux pc too.
Reply 15 of 15, by momaka
n0vac_ wrote on 2024-06-22, 19:32:
Well, let us know how it goes when you do.
BTW, no need to buy a new cooler and PSU. Used ones will suffice. For the PSU, just pick something that isn't a no-name brand. I don't know how Romania is with used parts, but south of you in Bulgaria, the prices of used PC parts are sometimes quite OK. OLX and Bazar are the two big sites we used for used parts. I think OLX is actually popular in several countries in Europe, IIRC.
