First post, by enb2002
- Newbie
I am setting up a Gateway G6-350 as a Windows 98 retro gaming PC, and I am using a Sound Blaster Audigy sound card in the project. I am using Joseph Joestar's Audigy drivers, and after installing the DOS drivers, whenever I shut down the computer or restart into MS-DOS mode, I get an error saying "Could not configure PCI Port". Despite this, when I load a game such as Tomb Raider, it works fine, sound and all in MS-DOS mode. I narrowed it down to when I remove the SBINIT.COM line from autoexec.bat, the error message goes away when I shut down the computer, but when I try to launch Tomb Raider in MS-DOS mode, the machine now hangs. Has anyone else encountered this issue before?
I am using a Sound Blaster Audigy model SB0090 with Joseph Joestar's Audigy drivers, and I followed the instructions for setting them up according to the original post here. One thing that may be important is that I used the Auto Patcher for Windows 98SE on this project to install a bunch of updates and utilities, so it's possible that some relevant system files have been replaced compared to a fresh Windows 98SE install.
