First post, by naujoks
Here I'm trying to revive a Gigabyte GA-586S.
I've cleaned it, replaced the missing battery holder, put contact cleaner in the sockets and checked for bad solder joint and broken traces.
I've tried two different CPUs (P166/P166 MMX) and a variety of RAM sticks.
I managed to install DOS alright but it now completely freezes either immediately or a second or two into trying to run a program, sometimes it freezes even during going through the AUTOEXEC.BAT.
It's running the latest available BIOS.
Any idea what might be wrong or what I could try?
https://theretroweb.com/motherboards/s/gigabyte-ga-586s
Reply 1 of 4, by dominusprog
Disable the L2 cache in the BIOS and see if it makes any difference.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 4, by ux-3
Does it run from floppy?
If you go HDD/CF/???, disable UDMA.
Retro PC warning: The things you own end up owning you.
Reply 3 of 4, by Gmlb256
Which DOS are you using? And how the HDD is formatted?
Reply 4 of 4, by Nexxen
"MADE IN TAIWAN", are those broken traces there?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
