First post, by charlysan
Hello,
I've already asked this on vcfed, but have not received any answers so far. So, I'm duplicating that thread here in case someone can help:
Does anybody have the pinout for the DE15 connector of this monitor for TTL configuration?
And what about these switches?
SCAN (WIDE/NORM) -> Maybe WIDE: 15.5-35.5 KHz; NORM: 30-35.5KHz (?)
MODE (NORM/PRESET) (?)
TTL COLOR (8, 16SAT, 16PAS, 64) (?)
Some links:
- https://hu.wikipedia.org/wiki/Schneider_Euro_PC
- https://www.wikiwand.com/hu/Schneider_Euro_PC
- http://amiga.unikko.org/C-lehti/html/1990/5/
The attachment is no longer available
Thanks!
Reply 1 of 17, by darry
charlysan wrote on 2024-06-20, 19:29:
Hello, […]
Hello,
Some links:
Thanks!
According to https://forum.atari-home.de/index.php?topic=281.0 (not too authoritative, I will concede) it was made by Mitsubishi .
Assuming that is accurate, you might get lucky and find an equivalent or similar Mitsubishi model for which more documentation has survived.
EDIT:
It looks similar to this Mitsubishi FA3415
https://forum.vcfed.org/index.php?threads/dig … r-pinout.68719/
And Schneider seem to have what is possibly a rebranded version :
https://ia904504.us.archive.org/17/items/manu … CHNEIDER_EN.pdf
Reply 2 of 17, by charlysan
Thanks! This is super useful! I will validate and post the discoveries and results in the following days.
Reply 3 of 17, by darry
charlysan wrote on 2024-06-20, 20:13:
Best of luck and welcome to Vogons!
Reply 4 of 17, by rmay635703
You should take off the cover and see if you can trace it out because there are multiple ways of wiring TTL on a 15pin. You also need to be very careful you identify any pins that go to ground or any uncontrolled voltage.
One of my old screens with a proprietary connector and pinout had color coordinated wires going to each pin making it easy to know what the pin did.
The mitsu pinout is most likely but there is also an NEC pinout and the below pinout that are possible.
1=GND
2=R'
3=R
4,5=nc
6=VSYNC
7=HSYNC
8=nc
9=key
10=G'
11=B'
12=nc
13=G
14=B
15=nc
Reply 5 of 17, by charlysan
rmay635703 wrote on 2024-06-21, 04:48:
You should take off the cover and see if you can trace it out because there are multiple ways of wiring TTL on a 15pin. You also […]
1=GND
2=R'
3=R
4,5=nc
6=VSYNC
7=HSYNC
8=nc
9=key
10=G'
11=B'
12=nc
13=G
14=B
15=nc
Yes, I will do a closer inspection and measurement before injecting any signal, and I will take the AOC pinout as a starting point.
Reply 6 of 17, by charlysan
I found the original cable used with this monitor for TTL video:
Label: CABLE-FA12
The attachment cable_fa12.jpg is no longer available
The attachment connectors.jpg is no longer available
Pinout:
The attachment ttl_pinout.png is no longer available
Reply 7 of 17, by mkarcher
charlysan wrote on 2024-06-22, 19:53:
The pinout of that cable seems to match the Mitsubishi pinout.
Reply 8 of 17, by charlysan
Juko XT clone + CGA card + MS14:
The attachment ms14_xt.jpg is no longer available
The attachment ms14_glabios.jpg is no longer available
The attachment ms14_checkit.jpg is no longer available
The attachment cga_prince.jpg is no longer available
Reply 9 of 17, by darry
charlysan wrote on 2024-06-25, 23:54:
Juko XT clone + CGA card + MS14: […]
That looks nicely sharp and well converged.
How bright is it ?
Reply 10 of 17, by charlysan
darry wrote on 2024-06-26, 04:19:
How bright is it ?
Brightness is good. Pictures were taken with brightness at 50%. I will soon upload some examples using different color settings.
Reply 11 of 17, by charlysan
mkarcher wrote on 2024-06-22, 20:00:
Yes. And I don't see that the TTL/Analog switch changes H/V like the Highscreen MS 1024, so I guess the final Pinout for Schneider and Mitsubishi would look like this:
The attachment ms14_pinout.jpg is no longer available
Reply 12 of 17, by charlysan
charlysan wrote on 2024-06-26, 21:21:
I think I'm wrong about RGB analog pins. After looking at the schematics from FA3415 I see that RGB analog signals are coming from E2 connector, so they must be using pins 2, 4 and 10 from DE15 connector; however, I don't see that connection in the PCB diagram. I will have to open and inspect.
Reply 13 of 17, by charlysan
charlysan wrote on 2024-06-29, 19:58:
OK. I was able to measure between E2 pins and DE15 connector using an ohmmeter, and this is what I got:
DE15 - p2: Analog BLUE
DE15 - p4: Analog GREEN
DE15 - p10: Analog RED
Reply 14 of 17, by charlysan
Correction for the above for Analog pinout:
DE15 - p2: RED
DE15 - p4: GREEN
DE15 - p10: BLUE
DE15 - p8: V-SYNC
DE15 - p9: H-SYNC
DE15- p6: GND
Tested with Amiga 500:
The attachment ms14_a500.jpg is no longer available
Reply 16 of 17, by georgel
Thanks for your effort but this monitor is so rare I doubt anybody else has it these days. Was is it sold mainly in Germany?
Reply 17 of 17, by Deunan
A CRT monitor that can do EGA/CGA and emulate MDA in a chosen color as well? I'm envious. Last time I saw something like that the price was very unreasonable and frankly, from the photos, the tube was spent (not to mention had minor scratches).
