Hokay so I got the duplicate card in recently , but the system wouldn't boot with the card , the pcb looked pretty warped some maybe that was why , I pinched one of the filters from the dead card and used it on the working one , and the system booted with the non dead card , installing the drivers was a bit of a pain since it was all in Japanese and I nearly nuked my windows 3.1 install due to missing font issues.
The attachment 20240801_185155.jpg is no longer available
The card can go up to 1920x1440 in win 3.1 , or I can also go lower at 1280x1024 but run it at 16.7 million colors.
Weirdly the utilities for Win95 are worse than the decent 3.1 ones , and had a dingy little drop down menu , and I had to go into a .ini to manually set the refresh rate down to 75 from 87 because at 87 hertz the card kept running in interlaced mode.
The attachment 20240801_195726.jpg is no longer available
The attachment 20240801_195759.jpg is no longer available
The card can natively run croc in virge mode at 1024 , 768 which is nice , but not super useful cause its super slow,
also for some reason every resolution but 320x200 works well , which has artifacting , I'm not sure if its a ram issue or not ,
The attachment 20240801_212056.jpg is no longer available
The attachment 20240801_212035.jpg is no longer available
I also tried epic pinball in DOS 6.22 and the very upper right corner edge was missing a few pixels , but only in the table select menu? , which is odd.
I guess I can always steal the ram from the dead card to fix things , if that's the case , unless its something to do with the card bios not liking certain modes?
Anyway ill have to do more testing.
