My findings:
The ADV probably stands for "Advantage". Some sort of value line I suppose.
GPU-Z identifies the chip as an RV370.
The attachment x550.specs.gpuz.gif is no longer available
The PCI ID is 1002 5B63 - 174B 1490
and the BIOS version is VER008.015.158.000
I don't know how accurate GPU-Z actually is because if I click Look up it doesn't list this specific model, it gives me two options:
ATI Radeon X550 HyperMemory (RV370 PRO)
https://www.techpowerup.com/gpu-specs/radeon- … ypermemory.c516
X550 (RV370 LE / 215S8DAKA23F)
https://www.techpowerup.com/gpu-specs/radeon-x550.c120
OTOH mine looks very similar to this one (same fanless heatsink)
https://www.techpowerup.com/gpu-specs/sapphir … -advantage.b280
This one is listed as having an RV370 LE (215S8DAKA23F).
The ones you linked have a chip labeled 215RCAAKA12F, while mine reads 215S8CALA23FG.
So apparently 215 can mean both RV410 and RV370?
I still can't understand the rationale behind the 215 and all the other alphanumeric characters. Do you have more information on how to interpret them? How can one know if this is an RV410 and not an RV370?
Is it possible to flash a different BIOS and check how far it can be pushed?
Thank you for the information and your suggestions.
