First post, by heckpiet
Hi Guys,
I love DosBox it works very well for my Games.
But in my Company is and old Windows 95 with Dos 6.22 and on this running a old CAD Program called Mekon.
So what i have to do to get this one running ?
I'am useing the lastet CVS of DosBox dosbox_20050923
What have I to do to get DosBox with 1280 Revulution and VESA runnig.
What changes i have to made in my dosbox.conf ?
Have i to download additional driver or dll ?
Mekon get the error message:
ERROR VESA mode is not supportet by your card
Can someone help ?
Thanks
Peter
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
you would need to specify the things more clearly
which resolution is needed. high resolution is too vague.
The cvs you use of ykhwong has some 16 bit support. but no 32 bot
Water flows down the stream
Reply 2 of 6, by HunterZ
It sounds like he's trying to get 1280x1024 (or maybe 1280x960?) VESA working, although I'm not sure which bit/color depth.
Reply 3 of 6, by vasyl
If it is really some "old" program I would not expect it to require 32-bit color. My suggestion is to try ykhwong's build, use svgachipset=et4k or svgachipset=et4knew, load TLIVESA 1.1 or UNIVESA and see if that works. The second variation of chipset supports 1280x1024x16. DOS CAD programs often required high resolution but not that many colors so this might just work. The only issue is that the screen will appear broken after loading TLIVESA in "et4knew" case -- that's normal, it is a bug in TLIVESA.
Reply 5 of 6, by heckpiet
Hi,
tired diffrent videodrivers but dose not have the effect 🙁
On the Mekon Config is a entry with SET GDI_DRV=SVAGA256
SET GDI_MODE=VESA1024
Maybe that one will help a bit ..
Thanks
Peter
Reply 6 of 6, by vasyl
Not sure what you mean about videodrivers. Did you try ykhwong's build? From those settings it looks like Mekon requires 1024x768x256 mode, supported by Tseng ET4000 chipset in ykhwong's build. You will have to load DOS VESA TSR -- Tseng specific is TLIVESA.COM (available on ykhwong's website in Data/Util), otherwise use UNIVESA.
