First post, by rain
- Member
Hi i cant find right driver for this card. Games like motocross madness 1 and carmageddon2 running very slow.
Its pv-cl5465p+
_retired retro pc user_
Its pv-cl5465p+
Drivers can be had here : http://www.vogonsdrivers.com/index.php?catid=47
But I'm not all that sure it'll improve the games' performance. This is a Laguna3D card and they're not known for their performance... https://vintage3d.org/cirrus.php
Tiido wrote on 2024-06-30, 13:11:Drivers can be had here : http://www.vogonsdrivers.com/index.php?catid=47
Thereis no 5465 file on vogonsdrivers
There are several 546x drivers listed there. The x stands for any number in the series. This explicitly has 5465 in filename http://www.vogonsdrivers.com/getfile.php?file … 170&menustate=0
Cirrus Logic Laguna 3D has very low performance with bilinear filtering. Any game that can disable it benefits greatly.
Untested 5465pci driver. Download:
I personally have the agp version, so i used different driver.
If you want to use the tuner portion as well, then i have no idea. Try to find the manufacturers official driver to make that work.
TitaniumGL the OpenGL to D3D wrapper:
http://users.atw.hu/titaniumgl/index.html
The Serpent Rider wrote on 2024-07-03, 09:47:Cirrus Logic Laguna 3D has very low performance with bilinear filtering. Any game that can disable it benefits greatly.
I havent noticed anything strange. The card performs approximately equally to a sis6326. Its certainly not ideal for games released in 1999 or afterwards.
hi this is old thread i know but i would like to know is this card 8 mb or 4 mb? thanks.
Cpuz and dxdiag shows 4 mb but i believe its a 8
rain wrote on 2025-01-30, 12:40:hi this is old thread i know but i would like to know is this card 8 mb or 4 mb? thanks.
Take a look at your own picture - the card has two chips inscribed with GM73V1892AH16L. Google that and first hit is its datasheet.
As it says in the description: "DRAM organized as 2,097,152x9 bits" - so 2Mx9 (8 bits, 1 parity bit). 2Mb x 8 = 2MB. Two of those is 4MB.
Question: why do you believe it should be 8MB?
dionb wrote on 2025-01-30, 22:29:Take a look at your own picture - the card has two chips inscribed with GM73V1892AH16L. Google that and first hit is its datashe […]
Ebay seller tells me its 8 . but you r right its 4 mb :\ thanks
