First post, by wbahnassi
- Oldbie
Hi guys, I acquired a Dell OptiPlex 466 LE. The thing has a 486 DX2 66 CPU, external cache 0f 128KB, and 16MB RAM.
I added a sound card in it, and started testing some games, and found that it is behaving weirdly on certain games. Mortal Kombat 1 and Lemmings 2 mainly, and also Risky Woods.
In both MK and L2, music and sfx either work or don't.. mostly don't. Sometimes only music works, and sometimes only sfx, and most of the time neither. If music+sfx works, exiting the game then running it again will cause music+sfx to go away forever.. until I power cycle the machine, then the game of chance restarts.
Other games are totally OK. I tried Prince of Persia 1 and 2, Stunts, DOOM, SkyRoads, Island of Dr Brain, Conquests of Longbow, Terminator 2029. All are good and stable.
Some games are weird. Summer Challenge drops some sfx every now and then. Risky Woods has the jump sfx in chipmunk style (very funny).
All those games work fine on another 486 I have on the same sound cards I tried on this Dell.
Things I tried:
* Sound Blaster 16 ASP
* Sound Blaster Pro 2 (fixes Risky Woods)
* Sound Blaster 16 Vibra
* Change slots
* Change IRQ (5,7) Base address (220,240)
* Remove RAM (8MB, 16MB)
* Himem/Emm386 and vanilla (no Himem)
* Turbo ON/OFF
* Change HDDs (CF card vs. mechanical)
* Reserve sound card resources using Dell's ISA Configuration Utility
* Disable COM1/COM2/LPT1 ports in BIOS
What else could it be? This is the second machine I see that has weird sound compatibility issues (the first one was my Socket7 build). I feel I'm cursed. This is a branded machine so I was expecting good compatibility here... not some random "works once in a while" build.
If anyone has experience with this machine, let me know. I'd be grateful.
Thanks!
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
