First post, by AppleSauce
So pretty much the title kind of says it all , I swapped my 80 gig caviar black drive for a 80 gig intel ssd on my p3b-f rig winning win98se and imaged the hdd to the ssd using winimage, I used one of those sata to ide adaptors to connect it and it detected the drive fine but refuses to boot from it.
Is there a way to get it to work?
1.36 MiB
1.99 MiB
1.93 MiB
Reply 1 of 39, by H3nrik V!
Sounds a bit like some setting wasn't copied correctly, like "primary partition" or "active" or something like that.
Do you have a boot floppy so you can see if an OS sees the SSD?
Reply 7 of 39, by AppleSauce
Okay apparently the chip is a jm20330 , so that shouldn't be a problem apparently.
I don't get what gives , i got a msata drive to work on my socket 7 motherboard from 1997 but for some reason a 1999 slot 1 mobo won't play nice with a regular sata drive.
Reply 8 of 39, by darry
That's an odd one to me.
I have used a P3B-F with a variety of adapters, including JMicron and Marvell ones successfully. Samsung 860 series SSDs (possibly 870s too) are what I have I have used.
While I strongly suspect your issue will not be helped by it (your drive is smaller than 127GB) , maybe you could have a look at this or
even try it Adding XT-IDE option ROM to Asus P3B-F BIOS [Thanks to DenizOezmen, it actually works!!!] .
Maybe you are hitting some weird BIOS bug.
Reply 10 of 39, by AppleSauce
crusher wrote on 2024-07-02, 13:24:
Look at the partition style of your SSD in a modern PC.
Could be that for some reasons it's GPT instead of MBR.
Its MBR for sure.
Reply 11 of 39, by AppleSauce
I just tried the ssd on my current windows 10 pc (I'm facepalming for not trying this before) and it booted fine , well not all the way but that's because my win10 machine is too new for win98 , so that tells me the drive isn't the problem.
Its either the sata bridge controller or the asus bios.
1.09 MiB
Reply 12 of 39, by AppleSauce
darry wrote on 2024-07-02, 13:17:
That's an odd one to me. […]
You might be onto something , it might be the jmicron chip doesn't like my drive or some weird bios issue.
Reply 13 of 39, by AppleSauce
I installed the xtide bios but it doesn't seem to do anything. 😒
1.26 MiB
Reply 14 of 39, by konc
At this point I'd try to setup the drive from scratch on the target machine. This means connect it on a machine that it works, do a fdisk/mbr and delete all partitions.
Then if fdisk still doesn't work, you'll know it has nothing to do with the cloning and you'll have confirmed a hardware or BIOS incompatibility.
Reply 15 of 39, by darry
AppleSauce wrote on 2024-07-05, 10:09:
1.26 MiB
Did you enable it after flashing ?
You need to go to the CMOS setup and enable the Symbios SCSI BIOS.
EDIT: You may also need to either "disable" the IDE port you want to use in the main BIOS or set it to NONE (it has been a while and I can't test it right now) and make sure that SCSI is selected as one of the boot devices
Reply 16 of 39, by AppleSauce
darry wrote on 2024-07-05, 11:20:
Did you enable it after flashing ? […]
1.26 MiB
Where is the symbios option located?
Reply 17 of 39, by darry
AppleSauce wrote on 2024-07-05, 11:32:
1.26 MiB
In the main motherboard BIOS menu (CMOS setup). It is either named Symbios SCSI BIOS, SCSI BIOS or something similar. I do not remember exactly and can not check right now.
Reply 18 of 39, by AppleSauce
I found it already , thanks though for mentioning it even being there , i had no idea it had to be manually enabled in the bios.
1.96 MiB
Huzaah we have success! 😁
